6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
HELP!!!!!!!!pumped gas instead of diesel
Old 04-10-2013, 11:08 PM
redz284u's Avatar
redz284u
redz284u is offline
So my son put premium unleaded instead of diesel.........WTF. The station by our house (Exxon mobil)has green label for premium unleaded and that's what he put. I'm so pist I could @"$)(;:*^%#}{_\~€ŁĄ•. More so I'm post at myself. I should have not let him.
Anyways what now. I drained the tank. Put half tank with 20 oz of diesel kleen. Started up and no strange noises. He only drove about 7-10 miles.
Old 04-11-2013, 05:13 AM
senix's Avatar
senix
senix is offline
Received 1,465 Likes on 1,045 Posts
Change fuel filters and manually purge at the fuel cooler.
Old 04-11-2013, 07:03 AM
redz284u's Avatar
redz284u
redz284u is offline
Immediately? Or after I drive it some. Some are saying to drive it at highway speeds for a good ways.
Old 04-11-2013, 07:51 AM
senix's Avatar
senix
senix is offline
Immediately! Purge till you are sure it is straight disel. You do not want that in the HPFP.
Pull and replace the filters. I would even suction the fuel bowl as well.
Old 04-11-2013, 08:19 AM
redz284u's Avatar
redz284u
redz284u is offline
Crap I just drive it 45 miles to work. I'll see if there's any way to purge the HPFP here. Could it be done if I stuff some rags in there to soak up the fuel?
I hope I can make it home with out damaging anything. Hopefully that heavy dosing of diesel Kleen will get me there safe.
Old 04-11-2013, 08:29 AM
rbloodhound's Avatar
rbloodhound
rbloodhound is offline
Did you pump out the tank? How much gas was put in it?
Old 04-11-2013, 08:30 AM
senix's Avatar
senix
senix is offline
It is too late...don't bother now. You drove it and all that fuel that was in there has been consumed.
Change the filters though. That you can do easy whereever you are.
Old 04-11-2013, 08:46 AM
redz284u's Avatar
redz284u
redz284u is offline
Yes I cleared the tank, and drained the water separator under the driver side frame.
14 gal of gasoline were pumped in, and 20 were removed. When pumped said 50 miles to empty. After draining tank said 0 miles to empty. Pumped 20 gal diesel with 20 oz of diesel kleen
Old 04-11-2013, 08:55 AM
Tom's Avatar
Tom
Tom is offline
That's bad...
According to Ford, it's okay to drain the tank and flush the lines if the truck wasn't started. But if the engine was started the only authorized fix is complete replacement of the high pressure fuel system, which is typically over $10K.
I hope you were fortunate enough to get by without any damage, but I suspect damage has been done.
Old 04-11-2013, 09:03 AM
senix's Avatar
senix
senix is offline
Originally Posted by Crazy001
That's bad...
I agree, hope for the best. Watch for metal in the fuel bowl.
Old 04-11-2013, 09:04 AM
redz284u's Avatar
redz284u
redz284u is offline
What kind of damage? How do I detect it. How will I know? What do I look out for? Man I feel sick to my stomach.
Old 04-11-2013, 09:42 AM
senix's Avatar
senix
senix is offline
All you can do filters and inspect the fuel bowl.
If you were to ensure all is well then a complete flush of the fuel system would be required.
Truthfully is it too late for all that.
Shine a light in the fuel bowl. No rust/No debris or metal..then I suspect you are going to be ok. If your HPFP was going to lunch I suspect it would of by now or the signs are there.
If you see metal I would have it towed. At least the injectors will be saved at this point.
Old 04-11-2013, 09:48 AM
redz284u's Avatar
redz284u
redz284u is offline
So the rust and metal would be immediate? Like I can do this now and see if its gona be ok or not? Or do I have to let it run for a bit.
And the fuel bowl is the fuel filter housing in the engine compartment right?
Have your kids ever done anything like this. Or is it just mine??? I don't honestly know what to say or do. I know it just a car, but at what point do yah draw the line? He is freakin 20 years old. To old for this kind of mistake....... Sorry guys just frustrated here
Old 04-11-2013, 10:09 AM
senix's Avatar
senix
senix is offline
Fuel bowl is the fuel filter housing on the motor. You would see the effects almost immediatley, I believe.
No one drives my truck. Period..car yes.
Even if clean I would continue to monitor for awhile.
Old 04-11-2013, 10:13 AM
redz284u's Avatar
redz284u
redz284u is offline
Senix. I appreciate all your help and direction. Even though by the time I read it I had already made it worse. Thanks though. Ill monitor and hope for best.
Thanks to the others that shared some light to.
Quick Reply: HELP!!!!!!!!pumped gas instead of diesel
