ScanguageII
Anyone running a scanguageII on their PSD? Pros,cons,ect.....
Nobody is because you can't. PSD of this era is not OBD-II, so the gauge doesn't work.
Originally Posted by Evan_P
(Post 13050920)
Well, in case you're right, I'll tell you that I have a Scangauge II that I used to run on a GMC Canyon, and now use on a VW Jetta. I like the thing, the mileage calculation is pretty accurate once you've adjusted it over a tank or two. What info you can get out of it depends on what the auto make made available. it comes with programming instructions to read various "non-standard" parameters.
Originally Posted by JayFinAZ
(Post 13050974)
I know zero about PSD trucks. does your truck have an OBD2 diagnostic port? If so then the scangauge may work,but if not it won't.
