A/c ??
Old Jun 4, 2003 | 01:23 PM
stig's Avatar
stig
A/c ??
i had to put a used engine in my 2000 4.0 ranger this winter because of probable head crack. Now it seems to be running fine. However, now that it is warm out, i tried to turn the a/c on. No cold air. It worked with no problems last fall. I called the guy that put it in, and he said it must have had a leak at a fitting or something. My question is do you have to 'break' the a/c system when chaging engines? He said not always depends on the direction of the hoses off the compressor. I am suspect that when the change occured, perhaps the tech recovered the freon, but did not regenerate it after install....any thoughts on this would be appreciated....
Old Jun 4, 2003 | 01:31 PM
Rancha9's Avatar
Rancha9
A/c ??
OK, well, run to the auto parts store and pick up some R134 gages... These are indespensible and can save you big $$ on taking it to a shop... Those will tell you if there's a block/restriction in the system, or if there's even a charge at all. A couple other things to check that are cheap to fix are the compressor underpressure switch and the A/C system relay. These new R-134 systems are a snap to work on, as long as you take a little time to learn 'em... BTW, a Hayes A/C manual wouldn't help either... It lists correct A/C high/low ssystem pressures for different ambient temperatures and all sorts of goodies. Good luck!!!
Old Jun 4, 2003 | 06:40 PM
Ken00's Avatar
Ken00
A/c ??
You usually find a lot of dirt around a leaky connection because of the oil that leaks out.
Old Jun 5, 2003 | 07:49 AM
stig's Avatar
stig
A/c ??
system has been recharged. Shop had a guy replace engine. He recovered freon prior to engine swap. He neglected to recharge the system after. Shop did it for NC. Good deal...
f350Super99
Sep 3, 2015 07:25 AM
jim33067
Aerostar
Aug 24, 2012 10:21 PM
mblanken881
Feb 24, 2011 03:15 PM
griesera
Jul 28, 2006 09:05 PM
stangz
Nov 21, 2002 10:52 AM
