How difficult is it to replace a leaking fuel pump?
Old Apr 6, 2013 | 08:54 PM
guthrie&co's Avatar
guthrie&co
96 f 250 with a dripping fuel pump. How much of an operation is it to fix the leak or is it best to install a new pump?
Old Apr 6, 2013 | 11:02 PM
Talyn's Avatar
Talyn
Best off to usually install a new pump if you gotta fuss with it.
It's more of a hastle than it is hard to do.
the only hard part is turning the motor over to get the lobe top dead center.
There are a lot of how to's in the forum here for it.
Take a look at those and if you have any other questions beyond those, just ask.
It just sucks cause you gotta take out the fuel bowl and all that and get it out of the way and lay on the motor.
The banjo bolt can fuss with ya a bit too.
Old Apr 6, 2013 | 11:58 PM
fordman67's Avatar
fordman67
Like will said..pull the fuel boul assy.I have done many without...believe me.pulling it will save you much time vs. fighting it..AND you will need a big HONKIN wrench for the banjo bolt as well
Old Apr 7, 2013 | 08:21 AM
Talyn's Avatar
Talyn
my name says william, not will.
Old Apr 7, 2013 | 10:11 AM
guthrie&co's Avatar
guthrie&co
Sounds like a perfect time to re-seal the fuel bowl and replace the blue lines too.
Old Apr 7, 2013 | 10:34 AM
fordman67's Avatar
fordman67
I know it.I was wore out and couldnt type any more than i had to...fell asleep right after i think honestly.
Old Apr 7, 2013 | 11:39 AM
Furniture Doctor's Avatar
Furniture Doctor
Fuel pump
I replaced the fuel pump last May and I have a few tips. I bought a cheap wrench set from HF and bent the 1 1/4" with a torch to make it get easier to get the banjo bolt. I replaced all of the hoses with the blue ones. While I had everything apart I rebuilt the fuel bow. Another thing that I did was to use some thin thread to hold the washers while I fished the banjo bolt back in. The job is not hard but time consuming.
Doc
sbraatz
Apr 22, 2017 12:10 PM
woodtrucker
Mar 4, 2014 07:00 PM
wohurst
Jan 14, 2011 06:52 PM
lossscause
Feb 29, 2008 04:08 PM
BltFordTough
Jan 17, 2006 07:02 AM
