Bouncing with gooseneck.
Old Mar 26, 2013 | 06:59 PM
Splatts's Avatar
Splatts
At 50-55 mph truck bounces like crazy then smooths out. My horse trailer is an old steel trailer the weighs 4300lbs unloaded. I have the truck at the shop right now and I'm goin to have them change the carrier bearing balance the driveline and do the u-joints. I don't have time to do it myself since I'm movin the wife and kids back to Washington. Anyone else have this issue or any other ideas as to what this could be? I took him for a drive in it and the truck with no trailer normally bounces a little bit between 35-40 but this time it didn't do it at all. Go figure!!! With the trailer on it the bouncing is about 10 times worse!!
Old Mar 26, 2013 | 07:02 PM
Splatts's Avatar
Splatts
THE BIG MOVE IS NEXT WEEK!!!! AHHHH
Old Mar 26, 2013 | 07:17 PM
chunt's Avatar
chunt
I had the same vibration. I changed the rubber for the carrier bearing and it smoothed out some, but its still there. I wonder if the shaft needs balancing or the tires are out of balance.
Old Mar 26, 2013 | 07:18 PM
quesey's Avatar
quesey
my old gooseneck did that to. guess it depend's on where the axel's are on your trailer. mine were all the way back with no spring's. my bumper pull does it some but not as bad.
Old Mar 26, 2013 | 08:04 PM
Splatts's Avatar
Splatts
The truck did it all winter long with no trailer the bouncing that is. At higher speeds like 70 it turns into more of a vibration. Lets just say without a trailer u wouldn't want to stay between 35-40 or with the trailer between 50-55 if u had to pee.
Old Mar 26, 2013 | 08:14 PM
Splatts's Avatar
Splatts
My gooseneck horse trailer is 28' and the 2 axles are about 6' from the rear with springs. It feels like it is coming from the truck also because it does it with no trailer. Oh but not when I got a mechanic in the truck. Lol
Old Mar 26, 2013 | 09:14 PM
FI460's Avatar
FI460
Could it be the placement of the hitch? I recall hearing about something similar when a 5th wheel was too far back.
Old Mar 26, 2013 | 09:43 PM
Splatts's Avatar
Splatts
The hitch is a little infront of my rear axle. The bouncing it does without a trailer gets worse with a trailer.
Old Mar 26, 2013 | 09:59 PM
ReBilld's Avatar
ReBilld
Did you check the air in your inner duals?
Old Mar 26, 2013 | 10:20 PM
Splatts's Avatar
Splatts
Ha ha ha ha yeah I checked that first thing. Lol dang someone remembered. Do u think the work on the driveline will fix the bouncy bouncy??
Old Mar 26, 2013 | 10:45 PM
ReBilld's Avatar
ReBilld
LOL! Just giving you a hard time bud! LOL! The work on the driveline is definitely a good place to start for sure.
Old Mar 26, 2013 | 11:57 PM
Splatts's Avatar
Splatts
Yeah Check. Lol. I ain't got much time moving to Washington next Wed or Thurs. I sure hope this does the trick.
Old Mar 27, 2013 | 03:17 AM
stainlessstroker95's Avatar
stainlessstroker95
How old are your shocks? Maybe some stiffer, heavy duty ones are in order. My truck bounces crazy with no shocks on it. My shock mounts rusted off thats how i know, haha.
Old Mar 27, 2013 | 09:57 AM
superduty4x4's Avatar
superduty4x4
Carrier bearing is my bed. Where in WA are you headed to?
Old Mar 27, 2013 | 11:02 AM
Splatts's Avatar
Splatts
Tri cities area. Kennewick.
