MPG
Old Apr 5, 2013 | 10:24 AM
6brau's Avatar
6brau
MPG
Ok i know this is a dumb question, but i am 16 so i need a truck a little better on gas mileage than a full size. I recently test drove a 5 speed 1991 f150 with my dad. It has a straight six in it, rather than a v8. We are thinking about getting it. What do you think it gets mpg wise. Thanks
Old Apr 5, 2013 | 10:31 AM
stewart89's Avatar
stewart89
Couple questions first. Is it running tip top? What's the rear gearing? 2wd or 4wd? Bed/cab config? Tire size?
Old Apr 5, 2013 | 10:32 AM
SideWinder4.9l's Avatar
SideWinder4.9l
If it's a 2 wheel drive and 3.08 gearing (Code 18 or H8 on the Door Jamb Sticker)
14-16 in town, 16-17 mixed and about 18-20 highway.
4x4, or lower gear ratio's (3.55 is code 19 or H9) you'll see 1-3 lower mpg.
Old Apr 5, 2013 | 10:36 AM
blue924.9's Avatar
blue924.9
all depends on the previously stated and how you drive it i can get 22 but i drive 90 percent highway have no ac and set the cruise right after it hits overdrive. and i have some other stuff
Old Apr 5, 2013 | 10:41 AM
SideWinder4.9l
This is true.
I can go from 15-16 in town, to 12-13 easily, if I really romp on the throttle (I have a theory on mpg/I6 mpg that has actually been consistent, but that's a different thing)
with tires properly inflated, good driving technique, and a standcab/long/shortbed truck....You should see the #'s I mentioned.
Old Apr 5, 2013 | 11:42 AM
hotrod351's Avatar
hotrod351
i get 16.5 mpg with my straight six and automatic trans.
Old Apr 5, 2013 | 01:21 PM
6brau's Avatar
6brau
Ok well i live 5 miles from town, so i probably will not get that good of mpg. right?
Old Apr 5, 2013 | 01:43 PM
Conanski's Avatar
Conanski
An I6 truck with 3.08 gears is pretty much useless as a truck so you may as well have a small car, it'll get 3 to 4 times better milage and be a whole lot more fun to drive.
Old Apr 5, 2013 | 01:46 PM
blue924.9's Avatar
blue924.9
one question how is it useless?
Old Apr 5, 2013 | 01:50 PM
blue924.9's Avatar
blue924.9
Originally Posted by SideWinder4.9l
This is true.
you should pm me this theory as i would honestly like to hear it
Old Apr 5, 2013 | 02:16 PM
Evan_P's Avatar
Evan_P
Those gears make it feel like a dog when driving. A small car will have a lot more get up to it, and get way better gas mileage.
Old Apr 5, 2013 | 03:02 PM
blue924.9's Avatar
blue924.9
thats what i thought, i dont mind it but hey must just be me. to the op here is a quetion i am surprised no one asked before me. do you have any NEED for a truck, do you haul or tow anything or do you want one just cause?
Old Apr 5, 2013 | 03:18 PM
Conanski's Avatar
Conanski
Well depending upon the transmission it could have a legal towing capacity as low as 2000lbs(my subaru has a higher limit), it'll be the slowest thing on the road not peddle powered, and driving around town it'll get low to mid teens fuel milage...my subaru gets 25min.
If you still want a truck why not look at a Ranger, as long as you don't buy a 4.0 4x4 with an automatic it'll get very good milage compared to a fullsize, our ext cab 3.0 5-speed manages mid 20s towing a landscape trailer around most of the time.
Old Apr 5, 2013 | 04:14 PM
blue924.9's Avatar
blue924.9
i see what you mean. when you said it was the slowest thing on the road you forgot about the dodge rams and dakotas with the 3.9
gtex
Jul 28, 2018 01:04 PM
95 Canoe Hauler
2009 - 2014 F150
Jan 2, 2012 04:49 PM
Torky2
Escape & Escape Hybrid
Aug 23, 2010 06:40 PM
lref250ld
Apr 2, 2007 07:11 PM
nationm
1997 - 2003 F150
Feb 22, 2005 06:36 PM
