06 Navigator code P0430. 89,000 miles
Old Apr 5, 2013 | 09:33 AM
akruck's Avatar
akruck
Engine was making a knocking noise heard outside of vehicle down low under the vehicle. Noise increased with throttle.
Engine light came on. Code P0430 came up.
Can a catalytic converter make the knocking noise I heard?
Knocking noise is now gone since the engine light came on. Did the computer retard timing to control knock and that is why I don't hear it now?
Is replacing the driver side catalytic converter the answer to the problem?
Can this replacement be done in my driveway?
Thank you.
Old Apr 5, 2013 | 11:24 AM
lv2race's Avatar
lv2race
If it's emmission equipment related, it should be under warranty for 8 years or 80,000 miles.
Old Apr 5, 2013 | 12:35 PM
alloro's Avatar
alloro
Did you look under the truck to see if the O2 sensors after the cats were intact? The knocking noise could be a broken O2 sensor laying against the exhaust.
If they're both intact then it is probably a bad cat. The honeycomb inside can break loose and rattle around. Like lv2race it might be under warranty. Most manufacturers have to cover cats for something like 100K miles.
Old Apr 5, 2013 | 01:09 PM
akruck's Avatar
akruck
Thank you both for taking the time to reply.
My understanding from reading the warranty manual, is that cats are warranteed for 8 years or 80K miles. As stated, my Navigator has 89K. So, I assume I am out of luck for Ford picking up the tab.
No O2 sensors are loose. I thought usually when the cat beds go out, they rattle like marbles in a coffee can, not make knocking noises.
Thanks, Andy
Old Apr 5, 2013 | 01:43 PM
lv2race's Avatar
lv2race
Thanks, Andy
Next time I'll pay closer attention to the title Hopefully your truck is new enough that they may cover it, if that is the problem. It may worth a call to the dealer.
mwacosta$
Dec 30, 2011 03:38 PM
scoony
2004 - 2008 F150
Jul 22, 2011 06:24 AM
Robwif150
1997 - 2003 F150
41
Aug 12, 2010 07:06 AM
RUSTANG67
2004 - 2008 F150
May 21, 2009 12:07 AM
sixstring610
Apr 18, 2009 07:08 AM
