Front Right wheel locks up
Old Apr 4, 2013 | 10:25 AM
jstackhouse04lariat's Avatar
jstackhouse04lariat
Cool Front Right wheel locks up
I was driving down the road and started to brake for a stop light, at about 20mph my truck (2004 F150 super crew Lariat 4x4 with the 5.4L V8) started to shake violently, and grinded to a stop. I stop put my flashers on and then walked around the truck thinking I hit something or something came off. Nothing appeared out of the ordinary. So i got back in and kept going and it was fine for about 20-30 feet. Then I heard a huge snap and the truck abruptly stopped and almost took me out of my lane due to the shaking. I pulled over, turned it off and got out. There was no oil or liquid dripping from the truck so I said What the hell is going on!. I got back in one more time and put it in Drive and the truck acted as if the parking brake was on and would not move. If Rev'd the engine over 2000RPMS the whole truck would shake violently and move very slowly. So i stopped and called a tow truck and had it brought home. I had to drive the truck down my driveway and the front right wheel locked up and i had floor it and spin the rear wheels to get it down my driveway. The front right wheel freezes in place after about 5-8 feet of moving in any direction. Im thinking its an axle or bearing? or Caliper failure?
Any ideas on whats going on??
Old Apr 4, 2013 | 07:29 PM
ojai150's Avatar
ojai150
I know exactly what it is,..happened to me 2 weeks ago. I was getting off the freeway and touched my brakes, wham,...I thought my right front wheel was locked up! I could move forward, but when I touched my brakes, WHAM !!! I pulled over, looked it all over, then saw a little worn groove in the inside of the wheel where something was rubbing. I crawled under and could see the lower bot holding the caliper was missing. In MY case the larger bracket that the caliper bolts to. I got a ride to Ford, got 2 new bolts just to be safe, changed them out, and good to go. Sounds like your caliper is really jammed into your inner wheel. Please let us know what you find.
I recently did a complete brake job plus ball joints and figure I got distracted and didn't torque the bolts tight enough.
Old Apr 4, 2013 | 07:44 PM
jstackhouse04lariat
Im gonna go out and take a quick look at everything. Ill let you know if i find anything. Thanks
Old Apr 5, 2013 | 12:22 AM
jstackhouse04lariat
You are 100% correct. My lower caliper mounting bolt is gone which made the caliper hang down ad get in contact with the rim. Thanks for help
Old Apr 5, 2013 | 12:34 AM
ojai150's Avatar
ojai150
Ha, I thought so, I couldn't imagine what the hell was wrong when it happened to me
Old Apr 5, 2013 | 05:50 PM
1979 Ford's Avatar
1979 Ford
I had a bearing go bad on my 98. Not quite to this extent. But a shop visit $120 later I was rolling again.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Oct 1, 2014 11:28 AM
bigtexan99
Dec 27, 2011 02:44 PM
mtong0001
2004 - 2008 F150
Mar 14, 2009 12:06 AM
Maddogv21
Oct 3, 2008 06:05 AM
hardknox00001
Nov 10, 2006 01:45 PM
