5.0 swap ignition help
Old Apr 3, 2013 | 08:40 PM
Mike ingram's Avatar
Mike ingram
Hi. I have swapped in a 84 5.0 in my 72 i6 truck(with much help from this forum). The distributor is from the 5.0 and has a 3 wire connector on it. Where do I go from here. What do I need to go to get it hooked up. What will I need to get and what from old set up can I use. My old coil was new accel unit. Thanks. Closer than ever !!!!
Old Apr 4, 2013 | 12:27 AM
67-F100's Avatar
67-F100
You need a duraspark box, or you can use a msd ignition box
Old Apr 4, 2013 | 06:50 AM
Mike ingram
So I need a dura spark box from the 84 mustang I assume. Do I need to remove anything from my current set up or will it be obvious. Thanks
Old Apr 5, 2013 | 10:26 AM
rustywheel68's Avatar
rustywheel68
or you could go the easier (and higher-performance than Duraspark) route:
Dirt cheap Ignition
BossFan
Electrical Systems/Wiring
Apr 21, 2017 05:08 PM
buldozr1
Jan 29, 2004 11:36 AM
mu5tanggt
Sep 8, 2002 10:53 PM
brett_d
Aug 30, 2001 06:54 PM
TallPaul
Apr 25, 2000 05:05 AM
