i have a c4 in my '77 f150 and the governor is out of a mustang which in turn makes it shift into drive at 18mph, does any have or know where i can get a heavier governor spring to delay the shifts thanks marty
It should adjust the timing as well are you sure that there is a modulator pin installed in the modulator?
Is there a difference between heavy and light throttle shift points?
well my trans builder said he put a longer pin in with the transgo shift kit instructions, i'm starting to wonder if it's just not long enough-I actually got the trans valvebody and governor out of a late 70's car but recently bought a governor for a '78-79 f150 302 c4, my exact setup making no difference. A guy on ford muscle sells a softer spring and says to drill and lighten one of the plungers and it will shift the way it should. The cam pulls 15in of vaccum in park so it's not terrible but i've heard that does make a big difference with shift timing though
Your C4 may have a spring and check valve that sits under the filter, if this valve is missing or in upside down it will stack shift regardless what is done to the modulator. This is the throttle relief valve when it is missing there will be no throttle pressure for the back side of the governor valve and it up shifts quickly when the drive shaft spins.
Valve first then the spring held in place by the filter.
a buddy of mine said to just run the modulator screw all the way in and if it doesn't shift back it out 1/8 of a turn? i never did this because i thought more than 3 turns from all the way wasn't recommended
Each longer pin will allow a later shift.
I use a piece of metal coat hanger. Just round the ends.
Some truck governors had a huge primary weight which allowed much earlier shifts. You may have to get a different governor.
I switched the governor from a car to a truck with no change, i'm going to try to play with the modulator and run it all the way in and back off a hair and see if that works, then i'll try different pin lengths
Also the driveshaft yoke is really loose going into the tailshaft-i have replaced the bushing twice, i even had a new ford yoke to test fit with no luck. I just bought a ford bushing so hopefully it's alot tighter, The truck is 133''wb and i'm running a 72.5'' long driveshaft, theres 4' of yoke showing but it goes into the tailshaft 2.5''. I mean you can move it up and down at least a quarter inch, horrible unbearable vibration above 45mph-what gives?
If you swapped from car to truck you went the wrong way.
Some C4's have an antigrunt sleeve on the output shaft.
If your yoke isn't machined to accept it you will have a problem.
By the sound of it you better do some corrective surgery in that area before everything is ready for PB&J.
will screwing the modulator all the way in and barely turned out going to be the same as running a longer pin back out more-as far as how firm it will shift?
Turning the screw in will raise the shift points a tad and make a harder shift.
