ford c4 governor spring
Old Apr 20, 2013 | 03:22 PM
bbf150's Avatar
bbf150
Originally Posted by jk080
Or just remove the vacuum line to see if it makes any difference.
Have you conformed that the valve and spring is installed correctly under the filter?
i haven't backed it out more than 3 turns from bottomed out to be honest-i heard that it wasn't good to exceed this-any reason why? it's drawing plenty of vacuum 15in with a gauge hooked up. I'm going to check that spring if this modulator adjustment doesn't do anything
Old Jun 13, 2013 | 07:11 AM
bbf150's Avatar
bbf150
backed the modulator out 1.5 turns from bottomed out, still shifts early to second and just right into drive. If i slow down quick in drive it will abruptly downshift to 2nd ? Just wondering if lengthening the pin will give it better driveability-maybe more vacuum cause it won't have to be screwed in so far ?
Old Jun 15, 2013 | 01:55 PM
stuart1's Avatar
stuart1
A longer pin may be the answer. I use a metal coat hanger.
Cdy1
1997 - 2003 F150
Jul 26, 2010 10:46 PM
FlyCool5.0
Mar 18, 2010 09:24 PM
clgreer
Oct 14, 2007 02:07 PM
Paul.Harrah
1978 - 1996 Big Bronco
Mar 5, 2007 12:35 PM
