6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Buzzing sound at start up
Old Apr 3, 2013 | 10:56 AM
Dorito's Avatar
Dorito
The other day I noticed an odd buzzing sound when I am waiting for the glow plugs to warm up. Its coming from behind the vent on the drivers side. I thought it was my glow plugs, but it continues after the light goes out.
Anyone else have this?
2008 6.4 KR CC 4x4 w/115k miles
Old Apr 3, 2013 | 03:10 PM
senix's Avatar
senix
Could it be your fuel cooler running low on coolant?
Old Apr 3, 2013 | 03:27 PM
CKetchum's Avatar
CKetchum
I have the same noise sometimes. This morning it did not happen. I have read on the forum about an air damper door solinoid not operating correctly or something like that. When my truck does make that buzzing while I'm waiting for my glow plugs to warm up, it goes away once the truck is started. I've been curious to it's exact origin...
Dorito's Avatar
Dorito
Maybe, I'll check it in a second, I have never had to add anything.
Old Apr 3, 2013 | 03:42 PM
Dorito's Avatar
Dorito
I just checked it, its about a ¼ cup low. ill add some when I get home and see if that helps. The truck runs fine, just a new weird noise.
I dont think its the air dampner door, its under the hood for sure. If it happened more often I'd have some one turn the key while I was under the hood. But it doesn't always happen.
Old Apr 3, 2013 | 05:17 PM
slowmans's Avatar
slowmans
Probably the Vaccum pump.
Old Apr 3, 2013 | 05:30 PM
senix's Avatar
senix
Good idea..I don't have the ESOF so that maybe a cause as well.
Old Apr 4, 2013 | 06:33 AM
Dorito's Avatar
Dorito
Nailed it, Is there any need to replace it? It seems to be doing it's job, just noisy at start up.
Old Apr 4, 2013 | 06:18 PM
slowmans's Avatar
slowmans
Mine runs occasionaly on start up, if yours is running continuosly I would look for a leak somewhere.
Old Apr 4, 2013 | 06:39 PM
CKetchum's Avatar
CKetchum
That's what is making the noise on mine. Found it finally today. Good tip! Only does it occasionally prior to start up. Seems like it stops after start up when it happens. I guess this is normal?
Old Apr 8, 2013 | 08:21 AM
Dorito's Avatar
Dorito
That is what mine does.
Old Apr 8, 2013 | 06:19 PM
slowmans's Avatar
slowmans
Mine does too.....I think its normal...
Old Apr 10, 2013 | 03:31 AM
aquaman's Avatar
aquaman
ditto here...
Ray Vaughn
Nov 23, 2014 12:29 AM
Jmartenskoop
26
Nov 6, 2012 09:10 PM
tjc transport
23
Feb 5, 2010 12:24 PM
RushN350
Jan 14, 2006 07:10 AM
levi'sford
Oct 31, 2004 10:07 AM
