Front End Noise
Old Apr 2, 2013 | 10:51 PM
Ford Ray's Avatar
Ford Ray
Front End Noise
Hello;
I have a 91 F350 2WD and I have an annoying and load front end rattle as I drive down the road. I have tried raising the front by the frame and by the I beam but I cannot locate the problem. I changed the wheel bearings. The noise goes away when I put the brakes on. I am thinking strut bushings or I beam bushings; what do you think?
Old Apr 3, 2013 | 12:06 AM
IowanStraight6's Avatar
IowanStraight6
Well there is no such thing as strut bushings on these trucks. My Money would be on the I beam pivot bushings or radius arm bushings.
Old Apr 3, 2013 | 06:01 AM
HrdDrv's Avatar
HrdDrv
Check the calipers and pads for play. When you hit the brakes, they tighten up against the rotor, stopping the rattle.
Hope this helps...
Old Apr 3, 2013 | 08:04 AM
Ford Ray's Avatar
Ford Ray
Thanks; "radius arm" is what I was talking about, on my car they face the other direction.
I did replace the rotors and pads and did check the anti-rattle clip to make sure it was in good shape.
is it difficult to replace those bushings?
Old Apr 3, 2013 | 08:23 AM
blue924.9's Avatar
blue924.9
ohh that was a big fail let me see if i can get that deleted
Old Apr 3, 2013 | 09:22 AM
xkpsanit's Avatar
xkpsanit
Uh no, looks nutin like that...ha ha
Old Apr 3, 2013 | 10:38 AM
blue924.9's Avatar
blue924.9
hey the second one worked i guess
White Mountain Goat
Aug 3, 2014 10:42 AM
BroncoIIboy946
Oct 23, 2006 12:04 PM
dpbrowne
Jan 21, 2005 03:54 PM
Ski
Mar 4, 2002 06:56 PM
pyro515
1978 - 1996 Big Bronco
Jan 4, 2002 07:48 PM
