1978 - 1996 Big Bronco
Automatic hub's?
Old Jun 12, 2003 | 07:33 AM
AlM's Avatar
AlM
Automatic hub's?
yo,
Yes Tony told me he switched isp's; and I see that he had his bronco for sale. There are no cached files available on the www.
The conversion kit info is in Warn's Hub site.
http://products.warn.com/warn.nsf/wa...ucts.Main.html
"...H. When replacing automatic 3 hole cap screw hubs with manual hubs, you must purchase corresponding spindle nut conversion kit per application chart..."
Old Jun 12, 2003 | 08:24 AM
jbalestri's Avatar
jbalestri
Automatic hub's?
Correct, 5 screw auto hubs do not need the conversion kit.
Sorry, I thought you didn't see the link.
Old Jun 12, 2003 | 10:00 AM
Crazyromi's Avatar
Crazyromi
Automatic hub's?
Could I get a little schooling on the HUBs. What do they do? What is the difference between auto and manual? If and When do they wear out and how can you tell? Thanks for the help and please forgive my ignorance on stuff that seems to be pretty basic for most of you
Old Jun 12, 2003 | 10:07 AM
jbalestri's Avatar
jbalestri
Automatic hub's?
Best thing to do it do a search. Use the terms "auto manual hubs", and go down the page a little and in the center, there is a line that says "and older". Click that box. It will give you bunches of threads where this has been discussed before. If you still don't find what you are looking for, then post a thread with your question.
If you don't have 4x4, you don't have hubs.
Old Jun 12, 2003 | 12:08 PM
steve83's Avatar
steve83
Automatic hub's?
...also, look here and here.
Old Jul 22, 2003 | 03:21 AM
geneb11's Avatar
geneb11
Automatic hub's?
I finally got around to it. The install was pretty easy. The only problem I had was getting that C clip out that holds that washer in. Once I got everything out the new lock slid right in and I put on the 2 clips and cap and that's it. The warn Premiums look a lot nicer than those plastic ones and have a metal **** which is stronger.
Old Jul 22, 2003 | 08:21 AM
jbalestri's Avatar
jbalestri
Automatic hub's?
Way to go!!!!!!
Yes, the Warn Premiums are all metal, including the part that engages the hubs. They should last forever.
Erik Sink
29
Sep 4, 2008 05:32 PM
nut1605
Jul 28, 2007 01:10 AM
BigGreen'77
Offroad & 4x4
Apr 12, 2007 07:11 PM
bud1963
Bronco II
Sep 7, 2005 09:04 PM
94Bronco58
Jan 31, 2004 12:05 AM
