steering column issues
Old Apr 1, 2013 | 10:27 PM
SilverSS's Avatar
SilverSS
My steering wheel was flopping around all over the place so I started to replace the upper steering bearings today. Got it apart and the upper steering shaft is worn pretty bad and also the tilt mechanism that houses the 2 bearings is in bad shape. Everything in there was toast. Apparantly it has been bad for some time. I think at this point getting a used steering column out of a junkyard would be a cheaper alternative. What steering columns will work on my 97 Expedition? Are F150's the same? Not sure what the junkyards around here have. Thanks for the help! I need to get this done so I can start on ball joints lol.
Old Apr 1, 2013 | 11:20 PM
1979 Ford's Avatar
1979 Ford
Yes, 97 to the 03 Expedition and F150 should be a direct fit.
Old Apr 2, 2013 | 10:24 AM
SilverSS's Avatar
SilverSS
Thank you sir
kevintoupin
16
Jun 22, 2017 04:30 PM
djmichael24951
Dec 6, 2015 04:34 PM
schlepprock250
22
Jun 3, 2011 03:51 PM
IDIDieselJohn
Jul 14, 2009 05:47 PM
tboneshep
May 21, 2001 09:38 AM
