Swapping out rear windows
Old Apr 1, 2013 | 04:02 PM
FordOwnerJoey's Avatar
FordOwnerJoey
My 87 has a sliding glass window, but I might be trading my truck for my buddies 89 but it just has a regular window. I would like to swap them out.
How hard would it be to swap the windows, keep in mind neither one can break in the process. Also what are the steps in doing so?
Old Apr 2, 2013 | 09:11 PM
MeanGreen460's Avatar
MeanGreen460
2 guys works best doing this job .the warmer the weather the better .To do this job you need a piece of rope 1/4 dia and long enough to go completely around the inside window rubber with 2ft to spare .You can grease your rope if you like .You insert rope under rubber window seal on inside of truck window making sure your 2 rope ends are at the bottom middle of window prefer one foot hanging out each end.start pulling one end of rope while pushing out on glass when rubber and glass start clearing metal keep pulling Both sides of rope and pushing on glass when window is about half out make sure one guy is in back of truck to catch and hold window the gasket must come out with the glass .When putting back in put rubber window gasket on glass window rope back around rubber gasket to inside of window one guy pulls on rope inside truck while other guy pushes window in.basicly you are doing the reverse of taking out the window
Old Apr 2, 2013 | 09:56 PM
MeanGreen460
other thing you could do is have a body shop do your window swapping.should not cost that much 2 hrs for both trucks
Old Apr 3, 2013 | 11:24 AM
Freightrain's Avatar
Freightrain
Don't these have lock strips that need removed first? Then pull window out by pushing from inside around the rubber. Install window as mentioned, then install the lock strip using installation tool.
Lisle 47000 Windshield Locking Strip Tool : Amazon.com : Automotive Lisle 47000 Windshield Locking Strip Tool : Amazon.com : Automotive
Have to go look at the back of my truck. But I'm pretty sure it has lock strip. The older trucks don't(like my 67-72 models, I've put sliders in them).
It's not a difficult job, and unless you get careless you won't break the glass.
Freightrain
double post
skimtn
13
May 7, 2012 11:23 PM
nothercrash
21
May 25, 2011 07:59 AM
kitteekate
Aug 23, 2007 02:12 AM
Rayle979
1983 - 2012 Ranger & B-Series
May 13, 2004 11:03 AM
nitro94
Dec 28, 2002 10:40 PM
