Dieseling/idle drop
Old Apr 1, 2013 | 03:02 PM
SoCalExile's Avatar
SoCalExile
Dieseling/idle drop
I'm all smiles these last two days...I have to share.
Put it in and got it going yesterday:
<IFRAME height=315 src="http://www.youtube.com/embed/Y2iobh8Vnr0" frameBorder=0 width=420 allowfullscreen=""></IFRAME>
'71 F100.
'72 400ci, bored .040 over. I had the longblock redone at a place called Carolina Machine Engines in SC.
The cam is a custom Bullet grind; 519 lift, 270 duration similar to a Comp #224 with a slightly different lobe profile.
Comp springs, Scorpion 1.73 roller rockers.
Edelbrock 1405, which I'll have to upgrade to a 750cfm very soon (any recommendations?)
Hooker headers that feed into a set of 24" glasspacks.
Old Apr 4, 2013 | 07:51 PM
SoCalExile's Avatar
SoCalExile
Help!
Update: had some issues with dieseling. I swapped the RS 333-192 thermostat with the 180* Stant for Clevelands.
It still ran-on so I re-adjusted the idle, which was at 1000rpm. Now having an issue where the truck drops idle drastically and wants to die at a stop. Tried adjusting the idle, the mixture, and the initial timing with some improvement.
Any suggestions?
Old Jul 6, 2013 | 02:19 PM
BuzzLOL's Avatar
BuzzLOL
.. Did you ever find the problem? I have a similar problem... suspecting dirt in the float bowl and/or idle passages of the carb...
Old Jul 7, 2013 | 08:18 AM
Filthy Beast's Avatar
Filthy Beast
Three month old thread - problem solved?
"Bigger" cam = more initial timing. Try 16 - 20 degrees.
Edelbrocks don't like/can't tolerate more than 5 psi fuel pressure. Ported/timed vacuum on the left, manifold on the right.
Vacuum leaks?
dnkensinger
20
May 24, 2016 09:50 PM
hivoltj
Aug 9, 2015 02:23 PM
Hypoid
Oct 20, 2004 08:04 AM
packlet
May 15, 2004 11:59 PM
Randyb12
Apr 18, 2004 06:18 PM
