Looks good! Surprised at how good the stick wheels look once they get wrapped in some decent tires. Did you do the install yourself? Have you had t aligned yet?
Hey thanks. I sure like the stock wheels. I always liked the factory look anyway.
My good friends shop (Home) put it on. I am not sure if they needed to align it, but they did.
You can deal with the cat two ways:
1-get a custom 2" diameter shaft made
2-cut 1/2"off the exhaust pipe that goes under the trans, then weld it up or a sleeve and a couple of clamps
If I was in the market for a lift, I would go with the BDS 4" 4 link and 37" tires. I also would get their replacement rear leaf springs instead of stacking blocks.
I may add the 4 link later but so far so good.
37s would really be pushing it with this lift but I'm sure it would work.
I think a couple asked for pics. Its amazing how normal it looks in a picture. The difference is much greater than the picture illustrates.
These are the Toyo AT2. I had the regular ATs on my last truck. The AT2s are still the same basic tread but the sidewalls are quite a bit more aggressive looking, which is nice.
Awesome... You know you're supposed to always post before and after pics to show off the difference...
