Fuel Pump Filter
Old Mar 31, 2013 | 10:04 PM
1966Jacked4x4's Avatar
1966Jacked4x4
Fuel Pump Filter
So I got a chance late today to see if I could track down my dead short and fix it temporarily until I get my wiring harness(Going to be meeting the manufacture at the local swap meet @ the end of the month).
So after no luck finding the short I moved on to fixing the breaks. When I crawled under it to break a bleeder, I could smell and see gas on the cement under it. So I had my friend turn it over and I found the problem real quick... It was pouring out of the fuel filter can on the fuel pump. After I removed the can I could tell the little rubber seal was hard as a rock.
So here is my question... Obviously I am going to replace the rubber seal... I am wondering if I should put some Teflon tape on the treads before I screw the fuel filter can back on. My buddy suggested it as an added help...
1. I am not sure it will need added help.
2. I am wondering if the gas will just melt Teflon tape.
The fuel filter can seems like it would be prone to leaking often.
Old Apr 1, 2013 | 04:45 AM
jowilker's Avatar
jowilker
While you are down there breaking things don't break the brakes, you will likely need them next time you drive.
Can't answer for certain but I wouldn't use the tape. You might brush the threads good before installing, my guesstimate if the pump has been on long enough for the rubber to crack & leak it's days are numbered anyways.
John
Old Apr 1, 2013 | 06:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
So after no luck finding the short I moved on to fixing the brakes. When I crawled under it to break a bleeder, I could smell and see gas on the cement under it.
Mine never leaked in 44 years (3/1965-11/2009)...preventive maintenance is the key. Hard as a rock gasket: Filter hadn't been replaced in a looong time.
People use an oil filter wrench to remove the cannister, causing it to twist, then split open. Check the cannister for cracks.
C4AZ-9365-B .. Cartridge Fuel Filter-Includes gasket (Motorcraft FG-1A) / Available from Ford/autoparts stores.
Myriad 1964/76 FoMoCo vehicles.
Nathan_FM
Jan 26, 2019 03:19 PM
riggerparish
Apr 3, 2013 03:22 PM
Ziegelsteinfaust
Mar 12, 2011 09:35 PM
D.J
Jan 16, 2008 05:46 PM
frigerator
Apr 18, 2004 11:09 AM
