Throttle Position sensor and transmission issues?
Old Apr 2, 2013 | 01:26 PM
blueray's Avatar
blueray
No CEL. I'll take a look at that though. What's the plug look like?
thanks!
Originally Posted by BennyLumpkin
Any CEL? Mine was doing this same thing and the solenoid pack in the trans was bad. Pull the plug on the right side of the trans on the top flat above the pan by the CAT. Use a mirror and see if there is any atf in it. If it is, its toast.
Old Apr 2, 2013 | 01:32 PM
BennyLumpkin's Avatar
BennyLumpkin
Grey plug. The wiring harness for it comes over the top of the trans in a heat sock and it goes straight down into the trans. There is two bolts to take off the little heat sheild by it and it gives you room to access it as its pretty tight.
Old Apr 2, 2013 | 02:42 PM
subford's Avatar
subford
ATF there just means the "O" ring is leaking.
ATF in a non conductor of electricity.
The black ring around the plug is the "O" ring:
Old Apr 2, 2013 | 02:45 PM
BennyLumpkin
Mine shorted the TOT sensor then solenoid #1....570.00 at the trans shop later it works great
Old Apr 2, 2013 | 02:58 PM
subford's Avatar
subford
What shorted it?
Oil can not short anything.
Old Apr 2, 2013 | 03:07 PM
BennyLumpkin
Don't know what caused it, I just know what codes it kept throwing and what fixed the problem and it was doing the same thing this guys is.
Old Apr 2, 2013 | 03:23 PM
subford's Avatar
subford
Blueray has not posted his codes but it might help if he did.
If you had two coils burn up at the same time that would be a little hard to believe.
Maybe you had very dirty ATF and the those valves stuck open.
Those coils have battery voltage on one side and the computer grounds the other side.
When any solenoid coil burns up it is from too much current going through them.
Did you have a bad computer or wiring shorting to ground also?
Maybe your alternator started putting out too high of voltage to cause the high current.
Old Apr 2, 2013 | 04:00 PM
blueray's Avatar
blueray
My CEL isn't on. I haven't tried to figure out how to short the connector and see if there are any stored yet. it will store codes, correct? though I've had the battery disconnected for 24 hours which may have erased them?
Old Apr 2, 2013 | 06:04 PM
subford's Avatar
subford
Yes you have lost the codes that may have told you your problem by unhooking the battery.
So you need to drive it until it does it again and then check the codes stored in CM.
First you do the KOEO electrical test and then you would have a pause and then see a one blip and then another pause and then you get the CM codes to flash out.
You can go to this link for more information:
Fuel Injection Technical Library » How To Run a Self-Test
Old Apr 13, 2013 | 07:54 PM
blueray's Avatar
blueray
Finally took to transmission shop, solenoid was bad for sure. They replaced that and when they drove it, found that third gear was out as well. They're not sure what it needs until they pull transmission out. Ugggghhhh ...
thanks for the suggestions!
xc4jokestomper
Sep 17, 2011 08:15 AM
TRUE IMAGE
Feb 2, 2009 02:19 PM
slicker_22
1983 - 2012 Ranger & B-Series
Sep 19, 2006 12:41 PM
jboard
Aug 22, 2005 07:28 PM
SupaFord95
1978 - 1996 Big Bronco
Aug 20, 2003 01:28 PM
