TPS sensor
Old Aug 22, 2005 | 10:56 AM
jboard's Avatar
jboard
Unhappy TPS sensor
How do i check the TPS voltage? And whats is the voltage range suppose to be?
Thanks, Jeremy
Old Aug 22, 2005 | 07:28 PM
sailorpsycho's Avatar
sailorpsycho
If I recall right I read around here the TPS should read 1.0-1.1 Volts at fully closed throttle, and 3.8 to 4.3 volts at Wide open throttle but no more than 4.3 volts. Read the signal from the green wire on the TPS (center pin), with the engine warm and the key on engine OFF. Mainly you just don't want the cold idle solonoid screwing up your closed throttle measurement.
