Sponsored by: Real Truck
Front Unit Bearings
Old Mar 30, 2013 | 11:30 AM
Hokiewheeler's Avatar
Hokiewheeler
Front Unit Bearings
Well I just had my power steering pump replaced and the serpentine belt and had the trans serviced (If you are going to change yours and you have a 6.0 diesel, on some the radiator needs pulled and you will need a special wrench that you'll have to order to pull the fan off so you can get the shroud out of the way). Anyhow, I took a weekend trip and the front bearings start grinding around turns so I get to deal with that now too.
Is the dynatrac kit worth the upgrade? Any of you running it?
I'm looking at about 900 for stock bearings here locally, 1 yr warranty only. That's both sides. What else will I need to change as part of a unit bearing replacement (seals, etc)?
Old Mar 30, 2013 | 02:28 PM
dualwheels66's Avatar
dualwheels66
If you are keeping your truck for a long time, then the Dynatrac kit is well worth the price. When you use their kit you will only have to do it once then just check the bearings once a year. If the stock unit bearings fail, it can cause a lot of other problems. I have seen rotors get scarred, fenders get smashed from debris and wheels fall off, not a pretty sight. Oh and while you are in there, replace the u joints. I am still trying to decide on whether or not to buy a new truck, if I decide to keep my '08 then I will buy the Dynatrac kit along with a lot of other "upgrades".
Old Apr 1, 2013 | 11:11 AM
Hokiewheeler
I'm gonna have this truck for a while, but I think I'm going to go with stock replacements. I just don't have the time to get the dynatrack kit at this point with my only vehicle broke down, and the factory units gave me 95,000 miles. Hopefully I'll get better out of the moogs or timkens...
Having said that, do you need to replace the axle seal at the knuckle when you replace the bearing? Haynes doesn't say whether this is necessary or not.
Old Apr 1, 2013 | 02:00 PM
acf6's Avatar
acf6
$900 is pretty ridiuclous. you can buy timken wheel bearing assemblys for around $180 each and change one side in an hour in your driveway
Old Apr 1, 2013 | 02:52 PM
Yahiko's Avatar
Yahiko
I must agree. For that price they better be doing both and a few other things.
It's an easy job and you can do it at home with basic tools.
You can even find how to on FTE and some videos on Youtube.
Sean
Old Apr 1, 2013 | 03:10 PM
acf6's Avatar
acf6
Actually, if its an 05+, ive heard the wheel bearing assemblies are much more expensive
Old Apr 1, 2013 | 04:28 PM
Hokiewheeler
I ordered Moogs from RockAuto for 349 a piece. Best price I could find. They listed Timkens at 377, which I wanted, but when I tried to order them found out they were backordered. My truck's a 2007. Even the cheap no name bearings in the local stores are almost 300 bucks.
So I assume I don't need to play with the axle seal in the knuckle?
Old Apr 1, 2013 | 04:30 PM
acf6's Avatar
acf6
Ah, ok. The 05+ hubs are much more expensive for some reason. Moog will be ok to run
No you don't need to mess with that seal
Old Apr 1, 2013 | 04:37 PM
dualwheels66
Ford has a updated outer dust seal that's made a lot better than just the stock piece of rubber.
Old Apr 1, 2013 | 05:11 PM
Hokiewheeler
Cool, yall I appreciate the help, I'm gonna tackle these this weekend, I'll let you know how it goes.
Old Apr 1, 2013 | 08:58 PM
tsedgar's Avatar
tsedgar
Hawkerpilot05
Let us know how the Moog's are. I read their literature and they say they fix the weak areas of the stock unit with this upgraded unit. Curious how they work as I will be doing mine this summer.
Old Apr 2, 2013 | 05:05 AM
Yahiko's Avatar
Yahiko
Did you check with Tousley Ford Parts Depot ?
Most of the time there prices are very good. I have gotten
into the habit of checking with them before I order anywhere else.
Sean
Old Apr 2, 2013 | 08:36 PM
Hokiewheeler
I didn't as I wasn't aware of them. At any rate, ball joints are bad too. What is required to get those off? Looks like I gotta take the spring out to get on the nut on top.
Quick444
Nov 4, 2019 07:40 AM
trevorrules
Aug 9, 2013 05:23 PM
housedad
Sep 18, 2011 11:52 PM
AmericanMade
17
Sep 14, 2010 05:54 PM
jetjock16
Feb 22, 2005 09:48 AM
