Power window conversion
Old Mar 30, 2013 | 10:15 AM
granny_rocket's Avatar
granny_rocket
I'm looking to put power windows in my manual window truck. While a stock conversion would be as simple as finding a donor vehicle with a power setup that's not so easy for me as the junkyards around here seem to be picked clean of these types of donors...So I had the idea to get a power window conversion kit from jc Whitney.*
Has anyone had experiences with these kinds of kits? Are they reliable? Easy to put in or should I wait and hope to god I can find a donor vehicle for stock windows? *Im not overly concerned with appearances although stock look would be nice. I just want them to work! I don't mind a manual drivers window but reaching over to open the pass window for me is a pain. I have short arms And the cab is wide! LOL
Thanks for your input,
Al
1984 f-150*
Old Mar 30, 2013 | 07:00 PM
Franklin2's Avatar
Franklin2
I have never used the JCWhitney setup. With all the years available that would work, certainly you could find one in the junkyard?
All the places below in new Jersey had a right pass side window motor. I see even some of the car motors will work.
1985
Door Window Motor
Ford Truck F250 2 Door,STD,Power AA1336 $75 Giancola Auto Wrecking USA-NJ(East-Brunswick) E-mail 732-257-7495 / 732-257-7556
1986
Door Window Motor
Ford Truck F250 CLUB,XLT,PW C091 $40 1st Class Auto Salvage, Inc. USA-NJ(Trenton) Request_Quote 609-586-6222 / 800-360-2886 Request_Insurance_Quote
1982
Door Window Motor
Mercury Cougar exc. XR-7- RH REAR D263 $35 Dirkes Used Auto Parts USA-NJ(Mays-Landing) Request_Quote 1-800-328-9414 Request_Insurance_Quote
1984
Door Window Motor
Ford LTD RIGHT REAR 95-191 $35 Lafayette Salvage USA-NJ(Lafayette) E-mail 1-973-579-7428 / 1-800-579-5458
1986
Door Window Motor
Ford Bronco Full Size door, R. 0923H1 $Call Vern's Place 4 Parts USA-NJ(Millville) Request_Quote 856-459-3737 Request_Insurance_Quote
1987
Door Window Motor
Ford Ranger BB0514 $Call Giancola Auto Wrecking USA-NJ(East-Brunswick) E-mail 732-257-7495 / 732-257-7556
1986
Door Window Motor
Ford Ranger 31703 $Call B & B Towing USA-NJ(Morganville) Request_Quote 732-536-8030 & 732-536-8031 Request_Insurance_Quote
Old Mar 31, 2013 | 07:25 AM
granny_rocket
thanks Franklin, for some reason ive convinced myself I specifically need an 80-86 model for power windows...the only thing id need from our year trucks is the switch and or door panels. :::bangs head on wall:::
Have you ever done a conversion? Is it as simple as wiring power to the window motors or are there relays somewhere under the dash that needs to be hooked up?
Old Mar 31, 2013 | 08:57 AM
Franklin2's Avatar
Franklin2
I converted a 89 f250 once. But the guy just swapped the complete doors onto the truck with all the power stuff already in it. He didn't have the wiring harness though, so we had to hook it up ourselves, he had just cut the wires at the kick panel. It ended up being right many wires going from one door to the other(at least 5 or 6 I can't remember) but he also had electric locks. I installed a wire directly off the battery +, ran a short distance, and then put a 30 amp circuit breaker. I then ran this 10 gauge wire in through the firewall and use it to power the door locks and the power windows. The door locks have power all the time, but originally the windows do not. But we could not find a bad reason to have power all the time at the windows so we hooked them up to the same wire.
The fuse box may have a spot for the power windows, but it's usually not "loaded" or in other words it doesn't have the wire and terminal plugged in the back. But if you get the whole thing at the junkyard you can plug it all in.
Old Mar 31, 2013 | 09:20 AM
granny_rocket
Thanks! If I had a license I could be a legit electrician. I just get intimidated by "swap" projects because I wouldn't want to get half the stuff in and them find I'm missing parts I should have grabbed from the cab and now stuck with windows in the down position. Ha-ha! Just my luck.
I'll see what the junkyards come up with.
Old May 1, 2013 | 04:53 PM
Coonazz's Avatar
Coonazz
I did my 94 bronco with the motors and regulators from a 95 f150 standard cab, just drill out four rivets for each, they bolt in the same holes as your manual cranks, find any Ford switches you want to use, except if it has an Remote keyless entry, switches are wired different
Old May 1, 2013 | 04:55 PM
Coonazz's Avatar
Coonazz
I'll see if I can find my diagrams for the switches,
Rich G
Apr 22, 2017 09:51 PM
F-150 MP
2004 - 2008 F150
Jul 30, 2015 08:38 PM
Weaver76
Jul 26, 2013 10:51 PM
granny_rocket
Electrical Systems/Wiring
Apr 10, 2013 09:16 AM
mudsculpter
General Automotive Discussion
Aug 24, 2005 03:37 PM
