Rear Differential DeCode
Old Mar 30, 2013 | 07:51 AM
koski19's Avatar
koski19
Hey Guys....Need to get a rear differential decoded. 1997 F250 Heavy Duty 4x4 E40D with 7.3 Here's the info:
1st Line: S 132 N
2nd Line: L10 10 2 7E08
Always appreciate your input...
Jeff
Old Mar 30, 2013 | 08:35 AM
rodneywar's Avatar
rodneywar
based on the numbers you have a 410 limited slip the 4 before the l is usually hidden by the bolt it is a sterling 10.25
Old Mar 30, 2013 | 10:00 AM
koski19's Avatar
koski19
Thanks for the info....
Jeff
Old Mar 30, 2013 | 01:21 PM
rodneywar's Avatar
rodneywar
No problem
Old Mar 30, 2013 | 11:46 PM
redman84's Avatar
redman84
X2. You can also look at the door sticker. If the axle code is a 2 digit number or a letter and number ending in 5 then you have 4.10s. If it ends in 9 then you have 3.55s. The two digit number signifies open diff and the letter and number are LS diffs.
Old Mar 31, 2013 | 07:06 AM
koski19's Avatar
koski19
Got it...Thanks for your inputs......
Jeff
Super Duty Diablo
Feb 16, 2014 09:11 AM
mobriensnow
May 9, 2010 05:45 PM
cookieman69
18
Dec 26, 2009 10:57 PM
tomrooster-1
Mar 17, 2005 10:30 PM
