motor swap!
Old Mar 30, 2013 | 12:38 AM
brandon mauldin's Avatar
brandon mauldin
motor swap!
Hey guys, i have a 78 f150 with a granny 4 speed and a inline 6. I have a 351w that i plan on swaping with the inline 6 and i need to know if i should have some problems or would things bolt right up and be good to go??
Old Mar 30, 2013 | 05:20 AM
jowilker's Avatar
jowilker
brandon, You will need 302 pickup perches, about 69-79, the correct flywheel and clutch for the W and it should be pretty straight forward on the majors.
John
Old Mar 30, 2013 | 07:43 AM
MavSprint's Avatar
MavSprint
Don't know if these issues I had doing the I6 to V8 in my '70 F100 will apply to your '78 or not. The '70 I6 radiator outlet and the throttle linkage were both on the wrong side. I used V8 radiator and throttle pedal/lever.
Also eliminated the throttle linkage bell crank and used a straight 9.5" or 10" (can't recall right now) swedged rod and helm joints from Speedway.
The oil pan I used was a front sump but the engine sits so high I think any oil pan would clear the crossmember and drag link.
Old Mar 30, 2013 | 01:00 PM
RichS2659's Avatar
RichS2659
John
Also, John, you can use 77-79 351M/400 perches as they are the same as 302 perches, as per Bill.
Old Mar 30, 2013 | 05:38 PM
jowilker's Avatar
jowilker
Correctomondo! No need to add to confusion is my thought.
John
Old Mar 30, 2013 | 08:09 PM
bmuhlbach's Avatar
bmuhlbach
a rear sump oil pan will work I have a 86 351W in my 68
Old Mar 31, 2013 | 11:29 PM
orich's Avatar
orich
Clutch linkage may be have a few issues too.
orich
ford5.8
36
May 20, 2012 09:40 AM
Farmall05
20
Nov 16, 2010 03:27 PM
luckyjoe
Engine Swaps
Jun 5, 2009 08:18 AM
osborn_1
Engine Swaps
Apr 5, 2007 09:34 PM
BigBrownTruck
Nov 2, 2001 11:42 PM
