Headlight issues
Old Mar 29, 2013 | 11:39 PM
davidjurss's Avatar
davidjurss
Headlight issues
So I recently purchased a 2006 King Ranch F150 that had aftermarket HIDs installed. I was getting flashed almost every time I drove at night, so I decided to replace the HIDs with Sylvania Silverstar Ultras and now the low beams are extremely dim. I've had Silverstars in an 08 Mustang and know they should be a lot brighter than what they are now. Also, when I have the low beams on my high beam indicator is dimly lit on the dash. I have read that it's possible that it's a ground problem, but when I run a jumper from the ground wire to the negative battery terminal it doesn't change anything. By the way, this is happening in both auto and manual switch positions. I travel on mostly unlit roads at night, and need my headlights to function properly. Anyone have any ideas?
Old Mar 30, 2013 | 01:48 AM
1979 Ford's Avatar
1979 Ford
Did you unhook the ballast that the HIDs require? Usually that is unplug the ballast and plug the harness in with the conventional halogen bulbs.
Old Mar 30, 2013 | 03:27 AM
davidjurss's Avatar
davidjurss
I completely removed the ballasts. The previous owner cut off the original connectors, and I had to rewire in new ones. I wired everything up correctly...at least I'm pretty damn sure of it anyway. The lights work, and high beams come on, it's just the low beams that seem to be really dim.
Old Mar 30, 2013 | 09:11 AM
1979 Ford's Avatar
1979 Ford
I had a Lincoln LS that I installed new headlights, the high beams didn't work. I kept the original harness. I swapped in original harness which fixed the issue. I guess I'd check voltage at the plugs for the headlight.
$ledgehammer
Aug 26, 2017 11:51 AM
Bulldog187th
Jul 19, 2017 08:10 PM
49fordv8f4
Jul 8, 2016 10:10 PM
Cody Wooters
1978 - 1996 Big Bronco
Jan 31, 2016 06:46 AM
nevi325
Jan 28, 2012 09:29 AM
