no brake lights
Old Mar 31, 2013 | 03:31 PM
  #31
redroad's Avatar
redroad
Originally Posted by Rob Cuenin
My brake light switch has a red and red/black wires to it, then red/black into steering column.
Yes that's what the diagram shows . Have you checked out the flasher relay? just bypass the brake switch for test purposes by unplugging both leads and clipping them together .. The brake lights should work ..
Old Mar 31, 2013 | 03:36 PM
  #32
wyckedcombo17's Avatar
wyckedcombo17
Okay, whole new ballgame now. Everything is plugged in right?
Red lead at red wire going into BOO switch, black lead at shiny metal. You should have 12v. Do you?
Red lead at red wire going into BOO switch, black lead at RED/BLK coming out. 0v when pressing pedal, or 12v?
0v = okay, 12v= bad switch, make sure its in adjustment before condemning
Old Mar 31, 2013 | 03:48 PM
  #33
Rob Cuenin's Avatar
Rob Cuenin
Can I use the turn signal flasher in hazzard flasher space? I only have one good one foe now,store run.
Old Mar 31, 2013 | 03:52 PM
  #34
redroad's Avatar
redroad
Look at the plug in lay out to see if they match and then look at the IDs to see if they are rated the same
Old Mar 31, 2013 | 03:55 PM
  #35
wyckedcombo17
Rob, did you do any of the tests I just told you to do? Please don't just throw parts at it.
Old Mar 31, 2013 | 03:57 PM
  #36
Rob Cuenin's Avatar
Rob Cuenin
Everything plugged in, SORRY for that,my bad.
1) 12v yes
2) 0 volt when pressing pedal
Old Mar 31, 2013 | 04:05 PM
  #37
redroad's Avatar
redroad
so unplug the leads from brake switch and touch them together if you have a helper at rear of truck .. otherwise alligator clip them and check brake lights yourself .. if this fails try again with unpluged Hazard relay
Old Mar 31, 2013 | 04:06 PM
  #38
wyckedcombo17
Not a big deal.
I'm assuming you had the leads as I told you, double check that.
We now know the brake switch is OK.
With red lead at RED/BLK at TSS, black lead at shiny metal with pedal depressed do you have 12v or 0v?
With red lead at WHT/RED at TSS, black lead at shiny metal with hazards on, do you have 12v or 0v?
If you have 12v at both of these, time to move on with diagnosing the TSS and read below. If not, we have a open somewhere earlier in the wiring.
With red lead at GRN or YEL/BLK at TSS (test both), black lead at shiny metal do you have 12v with pedal depressed?
With red lead at GRN or YEL/BLK at TSS (test both), black lead at shiny metal do you have 12v with hazards on?
Old Mar 31, 2013 | 04:28 PM
  #39
Rob Cuenin's Avatar
Rob Cuenin
1) 0 volts
2) 0volts
3) bolth 0 volts
4) 0 volts
Old Mar 31, 2013 | 05:48 PM
  #40
Rob Cuenin's Avatar
Rob Cuenin
Any thoughts on how to find this open(which wire) or fix this problem?
Old Mar 31, 2013 | 08:33 PM
  #41
wyckedcombo17
Did you touch your meter lead to the metal of the connector? Or, if you are poking a wire, are you sure you made contact with a conductor in the wire?
I find it very weird that neither input works, double check you are making good contact with your meter lead with whatever you are testing.
Old Mar 31, 2013 | 09:53 PM
  #42
redroad's Avatar
redroad
do you have speed control?
Old Apr 1, 2013 | 03:18 AM
  #43
Rob Cuenin's Avatar
Rob Cuenin
I have no 12v at red/black wire at tss. EDIT no power with pedal pressed
I have 12v at white/red wire at tss with hassard switch OFF but 0 volts with switch ON.
No speed control.
Old Apr 1, 2013 | 06:31 AM
  #44
redroad's Avatar
redroad
do you have 12v at tss red/black with brakes applied ?
and you said the turn signals work fine, correct?
Old Apr 1, 2013 | 06:57 AM
  #45
Rob Cuenin's Avatar
Rob Cuenin
I have o volts at red/black at TSS with pedal pressed.
The turn signals work great,all four corners.
