High RPM's?
Old Mar 30, 2013 | 07:51 AM
jim collins's Avatar
jim collins
An easy way to check your speedometer and odometer on the freeway is with a stop watch if you don't have a GPS or any other device to do it with. If traffic is light so you can keep a constant speed for about 3 miles or more do it this way. Get it up to where you speedometer is showing 60mph, then at the first mile marker post along side the roadway start the stop watch. Time it between the mile post, 60 mph is 1 mile in 60 seconds . In other words get it to the speed it takes to hit each mile post every 60 seconds and then look at the speedometer to see if it's showing 60mph or is it on 50mph or 70 mph, then you know how much it is off. You can at the same time see if your odometer is rolling over 1 mile each time it passes a mile post. Old school way of doing it but it works and you don't have to strain your brain doing a lot of math.
Old Mar 30, 2013 | 08:06 AM
meborder's Avatar
meborder
3600/time in seconds = speed in MPH
(edit ... use 3600 for one mile, so if you time 3 miles you need to multiply by 3)
mile markers are very accurate. I've measured them at work, and very seldom are they off far enough that they would throw your reading off by even 1 MPH.
i'm betting it is stuck in 2nd ....
Old Mar 30, 2013 | 08:24 AM
redroad's Avatar
redroad
I would agree it's not shifting out of 2nd .. pull the vacumm line at the modulator and see if tranny fluid is in the line if so replace the modulator
Old Mar 30, 2013 | 08:41 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Great now I am wondering about my ol silver truck and is it really shifting right.....
Old Mar 30, 2013 | 01:35 PM
SuperDuty93's Avatar
SuperDuty93
Whats the modulator look like?
Old Mar 30, 2013 | 01:42 PM
SuperDuty93
Ok found it. And well when i pulled the rubber hose off nothing dripped out. But it kinda looks like inside the hose might be damp? If i replace it will fluid come spilling out?
Old Mar 30, 2013 | 02:04 PM
redroad's Avatar
redroad
No fluid won't spill out only if motor is running .. Have you determined that trans is not shifting into 3rd gear?
Old Mar 30, 2013 | 02:16 PM
SuperDuty93
Just went for a test run. It goes into 3rd...... But what i did notice is there isnt much was a decline in RPMs when it does shift. Maybe 500 rpm drop when it shifts? I couldnt pay alot of attention to the tach cuz i didnt wana run anyone over in the neighborhood haha. But for a fact it does go into 3rd. So im thinking the mechanic counted teeth wrong when he was looking at the rear end or the previous owner had the tranny rebuilt and someone changed out the gearing in it.... Or the less likely but possibility that im going way fast then i think when i dont have the gps in the car.
Can someone tell me what stock tire size was on a 74 highboy? Then i can do the equation to see what gear thing i need for the speedo.
EDIT: Im starting to think the mechanic counted the teeth wrong.....
Old Mar 30, 2013 | 07:06 PM
redroad's Avatar
redroad
The Highboy came stock with 4:10:1 gears if you have a Highboy .. It came with 8.00 x 16.5 rims .. The tire size may be on one of the tags on the truck .. The other thing you can do is pull the speedo cable at the tranny and ID the color of the gear..
https://www.ford-trucks.com/forums/9...ml#post9393390
Old Mar 30, 2013 | 08:59 PM
co425's Avatar
co425
Since your are shifting into 3rd. 10 bucks says you have 4:10 in the rear and not 3:73. I would pull alot higher rpms in mine when I had 4:10's in the rear. Time to pull the cover and read the build stamp in your ring gear or count the teeth.
Old Mar 31, 2013 | 12:15 AM
SuperDuty93
Whats odd is that when i bought the truck the PO put a 78 f250 front end HP D44 on and never checked the gear ratio. So i had the mechanic check the the front and rear gearing. He came back with 373 for the rear and 410 for the front. So what are the odds he did the rear wrong when he was counting teeth i assume?
Old Mar 31, 2013 | 01:21 AM
redroad's Avatar
redroad
Have you ever had the truck in 4wd ? if so you would have tore up the drive train if the gear ratios were anything but a match .. You report that you have a 1974 Highboy .. Then the rear axle is a 4:10 gear ratio unless it has been changed
Old Mar 31, 2013 | 01:30 PM
  #28
montana_highboy's Avatar
montana_highboy
At this point toss on another tach to either confirm or deny the numbers, something's obviously amiss, it may be the tach itself.
Old Mar 31, 2013 | 01:54 PM
  #29
parkerparkerm's Avatar
parkerparkerm
I know its Been ruled out as a tranny problem but my 76 wouldn't shift into 2nd gear because it was so worn out the gear was... Stripped I guess you'd call it.
wifes65
Jul 24, 2008 02:43 PM
6T6Shorty
Mar 17, 2007 11:22 PM
Renegade361
13
May 26, 2006 01:39 PM
superman64011
Apr 1, 2005 01:27 AM
moose94
34
Mar 7, 2004 10:41 PM
