Ford Relay???
Old Mar 28, 2013 | 10:25 PM
Super Econoline's Avatar
Super Econoline
Ford Relay???
i just wondering what differnt between color green and brown? is green for fuel pump relay? brown for ECA Power relay connector or ECC??? it from 89 ford E250
Old Mar 29, 2013 | 09:26 AM
Franklin2's Avatar
Franklin2
If you read the numbers on the relays themselves and look them up, you might be able to figure out what they go to. There are many different applications and uses for the different relays. I don't think there are enough colors to differentiate them all.
Old Mar 29, 2013 | 09:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Post the ID numbers marked on the relays, I'll tell you which is which.
Old Mar 29, 2013 | 09:10 PM
Super Econoline
green number showed E3TB-9345AA
but brown showed nothing no number anywhere on brown?
Old Mar 30, 2013 | 03:22 AM
NumberDummy
Originally Posted by Super Econoline
green number showed ID number: E3TB-9345-AA = original Ford part number: E3TZ-9345-A
Edit: F8PZ-14N135-AA (replaced F19Z-9345-A & E3TZ-9345-A) .. Fuel Pump Relay (Motorcraft DY-864) / See post 10.
Without an ID number on the brown relay, I cannot tell you what it is.
Old Mar 30, 2013 | 08:38 PM
Super Econoline
F19Z-9345-A (replaced E3TZ-9345-A) .. Fuel Pump Relay.
Thanks for info!! also i went ford dealer ask them about brown relay
they belevie it E7FZ-12A646-A or DY-514 for "ECA Power relay connector"
so does it sound right?
Old Mar 30, 2013 | 08:53 PM
Super Econoline
Ford Dealer seem give me wrong parts number i think it E6FZ12A646B is correct one for brown relay??????? here ebay link is http://www.ebay.com/itm/Motorcraft-DY502-Powertrain-Cont-Mod-Relay-1986-91-Ford-Mercury-/360436763034?pt=Motors_Car_Truck_Parts_Accessories&hash=item53ebb4899a&vxp=mtr
Old Mar 31, 2013 | 04:51 AM
NumberDummy
they believe it E7FZ-12A646-A (Motorcraft DY-514) for "ECA Power relay connector"
Without an ID number, I cannot verify. All I can tell you is this:
E6FZ-12A646-B .. EEC Relay Assy (Motorcraft DY-502) / Obsolete
1987/89 E150/350 300 I-6 / 1988/89 E250/350 460 / Also used on some cars, but I didn't look up the applications.
Last MSRP: $38.88 / Dealer net cost: $25.92.
There are dozens available NOS (New Old Stock).
Only MN dealer that has one = Chuck Spaeth Ford in New Ulm (507-354-3179). Call and do a comparo.
Old Mar 31, 2013 | 07:14 PM
Super Econoline
ford dealer and i figure right parts number is E7FZ-12A646-A (DY-514) that one is right... so now green relay F19Z-9345-A need motorcraft parts number?
Thanks,
Old Mar 31, 2013 | 07:29 PM
NumberDummy
ford dealer and i figure right part number is E7FZ-12A646-A (DY-514) that one is right.
So now green relay F19Z-9345-A need motorcraft parts number?
In-house FoMoCo Dealer Parts Locator System (website) says: F19Z-9345-A replaced by: F8PZ-14N135-AA (Motorcraft DY-864).
There was no Motorcraft part number for F19Z-9345-A nor E3TZ-9345-A that was replaced by F19Z.
MSRP: $21.53 / FTE Ford Dealer Parts Dept sponsor tousleyfordparts.com online price: $10.76 / Tousley Ford ~ White Bear Lake MN
Whiz down to your local dealer, see if you can find E7FZ-12A646-A listed for a 1987/89 Econoline.
Lotsa luck. 1980/89 Ford Light Truck Parts Catalog lists E6FZ-12A646-B / It's obsolete, there's no replaced part number for it.
How can you figure E7FZ-12A646-A is correct since you don't have this parts catalog? It's available on a CD from hipoparts.com
Old Mar 31, 2013 | 07:58 PM
Super Econoline
ford dealer parts dept did figure about E7FZ-12A646-A on his computer..
also i found Ebay http://www.ebay.com/itm/RELAY-ASSY-EEC-E6FZ12A646B-/200813386600?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec1691b68&vxp=mtr
will work same as E7FZ-12A646-A?
Thank you for help
Old Mar 31, 2013 | 08:04 PM
NumberDummy
E7FZ-12A646-A not listed in the 1980/89 Ford light truck parts catalog (3/1994 final edition) for a 1987/89 Econoline.
I ran (what this parts catalog lists) E6FZ-12A646-B on the Ford Dealer Parts Locator System. None of the 24 Ford Parts Depots have any and there's no replacing part number for it.
There are 35 available NOS
I have nothing to do a comparo with as I'm retired, sitting on my backside in my family room here in LA LA Land, using a laptop and a microfiche viewer, because my '80/89 catalog is on FoMoCo microfiche slides.
Contact Tousley Ford and ask them...as there's nothing else I can do.
Old Mar 31, 2013 | 08:15 PM
Super Econoline
i just got more info about E7FZ-12A646-A will be same with other parts number is
DY443, DY445, DY467, DY514, E47F12A646A1A, E4DF12A646A1A, E4DZ12A646A, E4TZ12A646A, E53F12A646A1A, E53Z12A646A, E53Z12A646A1A, E7EF12A646A1A, E7EZ12A646A, E7FZ12A646A
also can use "STANDARD MOTOR PRODUCTS Part # RY111 "
but will not work with E6FZ-12A646-B?
i have no idea if STANDARD Motor Products if they are good made parts?
Old Mar 31, 2013 | 08:55 PM
NumberDummy
inre to: E6FZ-12A646-B & E7FZ-12A646-A
Contact Tousley Ford (White Bear Lake MN) and ask them...as there's nothing else I can do.
Nothing!
Old Mar 31, 2013 | 08:57 PM
Super Econoline
..Nothing!!
Okay thank you and have good evening
