Hood pins
Old Mar 28, 2013 | 09:49 PM
FordYoungGun35's Avatar
FordYoungGun35
Hood pins
I just put a billet grille on and I have to go thru the grille in order to pop the hood, if I just pull the hood latch off and buy some good quality hood pins will the hood stay down? I've got a bug guard on it so not much air gets underneath it.trucks in my sig
Old Mar 29, 2013 | 08:27 AM
bashby's Avatar
bashby
There are 2 parts to the hood latch, the one that releases from inside with the cable and the one you reach through the grill. If you want to do hood pins, I would just disable the second latch and leave the cable operated one. You could just wire the latch to hold it open or cut it off. Another option would be to weld a handle on the second latch so it is easier to access with the billet grill.
Old Mar 29, 2013 | 09:10 AM
FordYoungGun35
So I can just remove the second latch? And would the hood stay down while driving lol I would hate to lose a hood
Old Mar 29, 2013 | 12:51 PM
bashby's Avatar
bashby
The hood should stay down with just the one latch. I HIGHLY reccomend some kind af second latch. I had a hood come open at about 40 mph once. Luckily I was on a back road and didn't hit anything. Broke the windshield, trashed the cowl and the hood of coarse got bent a little worse than it already was.
I just looked at my hood latch, it seems my idea of tying the second latch won't allow the hood to close. I think welding a small handle that you can reach would be the best thing to do... maybe just carry a screwdriver or something you can reach the latch with.
Old Mar 29, 2013 | 08:35 PM
Diesel_Brad's Avatar
Diesel_Brad
Or you just modify your hood latch so you can open it with the billet grill.
Use a pull cable
Or extend the secondary lever where you can reach it.
My Stull grill gave instructions where to cut a 3" hole into the header panel and a lever extension to bolt on to the stock lever so you can open the hood. VERY nice clean setup
Old Mar 29, 2013 | 09:14 PM
UNTAMND's Avatar
UNTAMND
How about maybe modifying a van hood latch or like the 80-86 ones where you reach between the hood and grill and push down.
Or weld a handle you can reach between good and grill.
Old Mar 30, 2013 | 01:17 AM
1993_f350_2013's Avatar
1993_f350_2013
i know this won't sound right but could you make it like say a 98 chevy suburbans?
Atwiss
Apr 16, 2011 01:13 AM
55FordLover
Jun 26, 2006 09:11 PM
DS02F250
Dec 12, 2005 01:01 PM
treebeard
1978 - 1996 Big Bronco
Nov 10, 2002 06:26 PM
