Shifting Arms
Old Mar 28, 2013 | 07:46 PM
Necco-2's Avatar
Necco-2
Shifting Arms
I have a 64 styleside with a 292 3 speed trans. Someone before me put a floor shifter in and discarded the shifting arms. I would like to put things back as they were but need the shifting arms. Does anyone out there have an extra set to sale or leads to fine them. Thanks Necco-2
Old Mar 28, 2013 | 08:33 PM
P38fighter's Avatar
P38fighter
Ask number dummy what the fitment is. What other years/trans will fit for you...
Old Mar 28, 2013 | 08:40 PM
Becky_is_a_66's Avatar
Becky_is_a_66
Dennis Carpentar has the arms that fit on the transmission (57-64) listed in their catalog for 10.00 each; however the lever arms at the steering column are listed for 65-72. Don't know which you are asking for.
Old Mar 29, 2013 | 06:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Necco-2
I have a 64 styleside with a 292 3 speed trans. Someone before me put a floor shifter in and discarded the shift rods from the trans to the steering column.
I would like to put things back as they were, but need the shift rods.
The 1st/reverse & 2nd/3rd shift rods are missing. The two levers on the trans may be present, as aftermarket 3 speed floor shifters usually connect to them.
It's also possible that the two manual control selector levers at the bottom of the steering column were removed. You're going to have to look and see.
You're probably going to need more parts, because most people install a floor shifter when the shift collar breaks (common) and/or the hole in the shift tube where the lever fits in, wallows out.
They don't know where to find the parts, so they install a floor shifter. Both the collar and shift tube are available NOS
C1TT-7328-F .. 1st/Reverse Shift Rod / Obsolete
Applications: 1961/64 F100/250 2WD 3 M/T / 1961/64 F100 3 M/T with Overdrive.
No Ford Dealer or obsolete parts vendor has any.
C3TZ-7326-E .. 2nd/3rd Shift Rod / Obsolete
GRIESEL MOTOR CO. in Okarche OK has 1 = 405-263-7242.
RED TAYLOR FORD in Corning AR has 2 = 870-857-3518.
Old Mar 29, 2013 | 08:56 AM
Necco-2's Avatar
Necco-2
shifting arms
Thanks one and all for the information. I checked and I do have the arms on the end of the steering column. I do not have the arms on the transmission. They have been replaced with the arm's that go with the floor shifter. I can purchase new one's from D.C. and will do so along with the new bushing kit. I still need the connecting rods. What if any other years will fit the 64. Thanks again you guys, you are always so helpful. Necco-2
Old Mar 29, 2013 | 11:01 AM
NumberDummy
Open your peepers and read post 4 again. I listed the part numbers and the applications for the shift rods. Found THREE of the 2/3 shift rods NOS
Old Mar 29, 2013 | 11:48 AM
Necco-2's Avatar
Necco-2
Ok, but does anyone have an extra 1st & Rev. rod that they would sell for my 64 F100
I also called Griesel Motors and they could not tell me the cost. The lady said they would e-mail me later !!!!. Thanks Number Dummy
Mav'_BlueF100
Feb 13, 2016 11:47 AM
SThompson
1961 - 1963 F100 Unibody
Aug 14, 2015 01:11 AM
stork1971
Dec 30, 2014 05:17 PM
clinkfield
Jan 21, 2012 04:14 AM
TALLBOY86B.C.C
Jul 7, 2011 03:54 PM
