loose steering, Shaft replacement?
Old Mar 28, 2013 | 11:36 AM
wycowboy's Avatar
wycowboy
Well hello all! i hope everyone has had a good winter.
now we have some warmer weather I was going to start working on the truck again. There are a few things I need to do. but one of the tings is our steering feels loose. I was told by a mec. that it was the shaft. I m having a hart time telling on line what part i need.. do you all have any recommendations or other thoughts for the loose steering?
Thanks much!
j
Old Mar 28, 2013 | 12:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Thanks much!
j
I bet are the BB.
Old Mar 28, 2013 | 12:22 PM
fordpride's Avatar
fordpride
It could be shaft, gear box, ball joints, tie rods or all of the above. You'll have to look and see what has play in it.
Old Mar 28, 2013 | 02:56 PM
wycowboy's Avatar
wycowboy
Well I just pulled the shaft, It seemed like there could be some play there, so i put it in a vise and crimped it just a bit tighter. This might have helped a bit but I could not tell for sure. I have replaced the gear box before on an other truck with the same problem and it did not work at all. so I am hesitant to replace the gear box till I know for sure where the problem is... is there any good way to test the all the components other than wiggling them till I find where it is loose?
what are the most common place for it to be loose?
thanks all
J
Old Mar 28, 2013 | 03:24 PM
madpogue's Avatar
madpogue
One inherent weakness is the rag-joint at the lower end of the shaft. Holdover from the horse-and-buggy days. Most aftermarket shafts have real live u-joints at both ends, and are much tighter between the inner and outer sections. But you still should check all the moving parts "downstream" of the box, as mentioned above.
mfhull
May 4, 2021 10:43 AM
adam83
Oct 24, 2017 08:50 AM
glovemeister
18
Sep 24, 2013 09:00 PM
drumfield
Mar 14, 2010 12:54 PM
standman
Sep 12, 2002 11:13 PM
