40/20/40 Split Bench Seat Mounting
Old Mar 28, 2013 | 09:51 AM
fordpower46's Avatar
fordpower46
Hey guys, I bought a 40/20/40 split bench for my 97 F250HD Super Cab and need the mounting bracket that allows the seats to be properly installed without drilling inboard holes and using spacers, etc. I work for a Ford dealer and have located a few places that have them but I want to verify the part number if anyone has that information to make sure I have the right bracket and not the small one that the '20' portion mounts to...
F4TZ-1860094-A
If anyone has the info I need, let me know.
Thanks!
Old Mar 28, 2013 | 11:52 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Brad (the other one) is going to assume I put you up to his. See this thread....
https://www.ford-trucks.com/forums/1...-bucket-2.html
Keep in mind too, the seating bolt pattern for the SuperCab is different than the Single/Crew cab. I don't think they made an adapter like this for the SuperCab - instead, the bucket seats were individually mounted directly to the floor.
Old Mar 28, 2013 | 01:01 PM
White 97 xlt's Avatar
White 97 xlt
True, each seat has it's own bracket in a Super Cab (and only SC).. The right bucket seat is on a slider, so that won't work with a "pan" mount.. The center seat bolts down with the same bolts that hold the inner brackets for the buckets.
Old Mar 28, 2013 | 01:16 PM
fordpower46
See, as I looked at it, this is what I thought. I got many conflicting answers as to whether or not I needed the pan mount. Looks like I will be installing the seats ASAP!!
Old Mar 28, 2013 | 01:26 PM
White 97 xlt
My truck is a '97 F250 XLT Super Cab, and that is the way they are mounted in it, there is a total of 8 bolts and all 8 go into the floor.
The bracket on the center seat looks like a butterfly that went through a hurricane!! I'm kidding of course , but it is big and goofy looking.
I've had mine out a couple of times, I have a 2-way radio control box mounted under the center seat, and it fits so close there is no way to get to the radio gear with the seat in there.
Old Mar 28, 2013 | 02:02 PM
fordpower46
Thanks White 97, this is exactly the answer I was looking for. Nice truck, by the way!
Old Mar 28, 2013 | 08:44 PM
Diesel_Brad's Avatar
Diesel_Brad
That part number will do the OP no good. That is NOT for his super cab.
To the OP. White 97 xlt hit the nail on the head. There are 3 separate brackets to mount the 40-20-40 in a SUPERCAB. One for each "40" and one for the "20". 8 bolts total hold the 40-20-40 in a super cab. The inner bolts for the "40" also hold the "20" into place
Old May 6, 2013 | 11:29 PM
Lookinfurfun's Avatar
Lookinfurfun
Can you post pics of the brackets and sliders for the supercab with 40-20-40 configuration? I'm switching from a bench, have the seats just need the brackets and sliders.
Old May 7, 2013 | 08:27 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Bucket seats in an extended cab don't use an adapter bracket - the track assemblies for each seat mount directly to the floor. But, those track assemblies will only work with seats that came out of an extended cab. Is that what you have? If so, I may have a set of what you need.
Old May 8, 2013 | 12:33 AM
Lookinfurfun
I have a 94 F150 Supercab and seats w/mounting brackets out of a non ext cab truck. Good price on the seats figured I could just get the brackets that mount in the ext cab to the seats I have. Sounds like it may not be that easy.
This is a pic of the seats and bracket type that I have (not my picture) http://www.supermotors.net/getfile/4...ts-removed.jpg
Old May 8, 2013 | 04:47 AM
Diesel_Brad
Those seats pictured ARE out of a SUPERCAB . there are 3 separate mounting brackets. a REGULAR cab and CREW cab use a a large seat pan(think of a bench seat) then the 3 sections bolt to it
Old May 8, 2013 | 10:35 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Brad agrees with Brad.
If what you have is exactly what's pictured above, just bolt them in and call it done.
Old May 8, 2013 | 04:13 PM
Lookinfurfun
YOu guys rock! Thanks for the quick replies The guy that I bought the seats from said that they came out of a crew cab so just have been searching to find the right braketry. Problem solved.
I've already shampooed the upholstery, took it off to add heated seats and bought some REAL nice neoprene seat covers from Cover King. This weekend I will be pulling the bench seat, adding some dynomat to the flooring and run my wiring for the seat heaters, new sub, overhead console and the power lumbar. Thanks again!
Old Jun 29, 2014 | 09:28 PM
Joe_fummins's Avatar
Joe_fummins
Clarifying
So I just picked up a set of seats like in the picture, I have an 89 extended cab, what am I looking at for install? I had a full bench so do I need to drill holes and if so is there any advice?
Fordication
May 31, 2018 04:39 AM
Snacky
Mar 20, 2015 05:54 PM
Dirtdog10304
May 1, 2014 07:40 PM
96f-250
Dec 8, 2009 04:59 PM
cowboyup1988
May 14, 2009 07:43 AM
