CAC TUBE QUESTION
Old Mar 28, 2013 | 08:53 AM
jerkypants's Avatar
jerkypants
CAC TUBE QUESTION
Hello Gentleman
I inadvertantly put a small dent in my cac (intercooler hose), I believe that is what it is called. It cracked and dented in, about the size ofa nickel. Can I patch it and run it to get the truck home? Marine tex or something?
I was doing the blue spring upgrade and dented it in on the bottom of the turn going up to the top of engine.
2005 F-350 superduty 6.0
also to replace it how does the bottom pull out? Do I have to turn it, do I have to remove the bottom holder for the air cleaner?
Any help is appreciated
Old Mar 28, 2013 | 11:20 AM
jerkypants's Avatar
jerkypants
BTW it is the long hose on the drivers side. It goes from the driver side headlight area, under the air filter housing and up to the top of the engine.
Any insight?
Old Mar 28, 2013 | 12:26 PM
ryhed's Avatar
ryhed
I don't think I would risk sening any plastic thru the airways. I guess in a pinch you might be able to get a muffler shop to fab you up a metal one. Mine is an 03 so its all metal. I know they sell them but your in a pinch. Metal Intercooler to Intake Tube6.0L Metal CAC tube, replace your cheap plastic one - PowerStrokeNation : Ford Powerstroke Diesel Forum
Old Mar 28, 2013 | 01:35 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Riffraff Diesel: Driver Side Metal Intercooler CAC Tube Kit
For $20 more than the BPD price you might as well get the better CAC boots right off the bat by shopping with RiffRaff.
Old Mar 28, 2013 | 02:01 PM
dannyboy950's Avatar
dannyboy950
For a temp fix you can use JB Weld just let it cure good before ya use it.
Iff all else fails I have used several wraps of ducktape just to get back. Be shure there is no oil residue on the surfaces.
Old Mar 28, 2013 | 03:25 PM
Misky6.0's Avatar
Misky6.0
I had to pull the battery, battery tray, and air filter to get both hands on the lower end of that cac tube in order to pull and twist and pull some more until finally it came out. Be careful i almost dropped the clamp into the intercooler openingcoonection when it separated and i was lifting it out.
Old Mar 28, 2013 | 04:09 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Part stores sell a two part expoy in a syringe specifically for plastic repairs. it works pretty well for a few months then tends to start peeling around the edges. repair on the outside only as the pipe goes right into the engine. skuff the area up with some 80 grit and hit it with some brake cleaner to give it the best chance of sticking well. should last long enough to get a new one shipped.
To get it back together easier warm up the end of the tube with a heat gun or hair dryer.
Old Mar 28, 2013 | 05:57 PM
Per4mance's Avatar
Per4mance
3M sells a silicone marine sealer called 5200. That stuff is double tuff and doesn't come off. I'd give it a shot just make sure you clean off all the grease with alcohol first so it can get some bite into the plastic.
Old Mar 28, 2013 | 06:26 PM
slimpick's Avatar
slimpick
Thanks everyone. I was going to use Marine-tex, it is pretty tuff stuff. I used it on the intake manifold on my Marquis. They put a plastic intake manifold on that engine and it cracked. Held for two years.
dj lpm
2015 + Expedition & Navigator
Jul 8, 2017 02:43 PM
Doward
May 8, 2014 05:01 PM
phish555
Mar 17, 2010 06:59 AM
PSDLOVER
Jun 26, 2005 10:48 AM
jpsartre12
Dec 2, 2003 09:07 PM
