sct programmer
Old Mar 27, 2013 | 06:57 PM
alexisvfd's Avatar
alexisvfd
sct programmer
i bought a sct programmer for my 04 6.0 and then i ordered 3 custom tunes for it but it can only hold 1...im a idiot i didnt know..is there anyway to delete the one i put on there to add the one i need..
Old Mar 27, 2013 | 07:11 PM
Lilpooh's Avatar
Lilpooh
No you can't delete, you can only over write the old tune. When you load on a tune from your PC to the SCT, the SCT LiveLoad software over writes a copy of the new tune in the SCT device.
You should of received custom tunes from a tune writer thru email, then save the tunes from email to your PC. When you load a tune from your PC to the SCT, it only loads in a copy to the SCT. The original tune/file will always be on your PC.
I would also suggest to save a copy of your tunes to a flashdrive or external hard drive for back up, just in case your PC takes a dump or someone accidentally deletes your tunes.
Old Mar 27, 2013 | 07:13 PM
Lilpooh's Avatar
Lilpooh
Oops, re-read your post. You need to download the LiveLoad software from SCT to your PC in order to load custom tunes from your PC to SCT device.
Old Mar 27, 2013 | 07:16 PM
alexisvfd's Avatar
alexisvfd
i saved all three to my computer but i thought i could down load all three but only one...it acted like it downloaded all 3 but when i plugged it in it only showed one..so your saying if i download the right one it will overwrite the one i dont want..........
Old Mar 27, 2013 | 07:32 PM
Lilpooh's Avatar
Lilpooh
Yes, pick the tune you want and load it. The old tune will be removed and the new tune will be installed.
Old Mar 27, 2013 | 07:34 PM
alexisvfd's Avatar
alexisvfd
k thanks alot
SPD&PWR
Sep 5, 2013 11:43 PM
bigugly78cj5
Computer Chips & Tuners
Nov 7, 2012 06:25 AM
KRDiesel
May 24, 2012 04:25 PM
amgpro2
Jun 25, 2010 03:07 PM
