how to rig a headlight buzzer and dash light upgrade
Old Oct 22, 2024 | 11:54 AM
75over77 F100's Avatar
75over77 F100
Here are the pictures of the buzzer.
Old Oct 22, 2024 | 11:55 AM
mterickson's Avatar
mterickson
I can't speak to the seat belt buzzer, both the light and buzzer work on mine.
As far as how you described how you wired the piezo, i don't think will work. You have 12v+ coming from the headlight switch and 12v+ coming from the ignition switch when key is on. You're not completing the circuit doing that, you're back feeding 12v from ignition switch to headlight switch and vice versa. You're using the piezo to tie both circuits together. Using those same wires in conjunction with the normally closed relay shown above should work though and avoid any sort of back feed from one circuit to another.
Old Oct 22, 2024 | 12:10 PM
mterickson's Avatar
mterickson
Looks to me the seat belt buzzer is a buzzer and relay all in one. Without looking at a schematic two of the terminals on that buzzer go to seat belt and when you insert the buckle it completes the circuit and shuts off the buzzer, it's probably a normally closed relay as described above. If seat belt is unbuckled the relay is closed and completes the circuit for the buzzer so it makes noise. Insert buckle, that closes the buckle circuit energizing the relay, opening (shutting off) the buzzer circuit. There's probably a capacitor of some sort buried in there too which acts like a timer to shut off the buzzer after a certain time period. I'd have to look at a schematic to confirm though.
Old Oct 23, 2024 | 06:28 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Oct 23, 2024 | 10:42 AM
75over77 F100
I am pretty sure those buzzers are just a reminder that cut off within a certain amount of time after startup but I may be . There do not appear to be any electrical wires attached to any portion of the belts but agree now that you mentioned it that the relay and buzzer are both inside.
I guess I can poke around with a test light at the harness where it plugs in and see what I can find out. From that I may be able to figure out how to bench test the buzzer.
I probably will not be able to mess with it for a couple of days due to work (damn bills).
Hopefully someone who already knows and will provide the details in the meantime.
Old Oct 23, 2024 | 10:49 AM
75over77 F100
I was looking for a pin diagram or schematic for the seatbelt buzzer and found a guy who made his own lights left on buzzer setup and thought it was pretty cool.
https://www.instructables.com/Buzzin...ight-Reminder/
Old Oct 23, 2024 | 12:39 PM
mterickson's Avatar
mterickson
The wires for mine going to seat belt are under the vinyl floor on driver's side, they come off the firewall near the high beam dimmer switch on the floor, run across floor under the seat to the driver's buckle that comes up through the seat, the electrical connector from buckle to wiring harness was under the seat out of view.
ljackson
2004 - 2008 F150
May 24, 2024 03:32 PM
aintskeered
Feb 20, 2012 09:20 PM
Jesse Zimmerman
Oct 9, 2009 02:35 PM
79 f-150 guy
Electrical Systems/Wiring
Aug 11, 2009 05:51 PM
isuzufan
1997 - 2003 F150
Dec 1, 2004 09:08 AM
