I'm in the process of installing the Sky Jacker dual steering stabilizer and the driver side stabilizer is hitting the part circled in red (not sure the name of it). With this on the way, I am unable to bolt on one end of the stabilizer. This part is not attached to anything other than its just wrapped around the bar -- not certain the purpose of this piece.
Can this part be removed without any negative effects?
It is the adjusting sleeve bracket. I would not recommend removing it. It is a means of ensuring the adjusting sleeve does not rotate if hit by anything you roll over.
The Adjusting bracket usually can be rotated out of the way. Just use proper torque on the bolts and don't rotate the adjusting sleeve.
Installed duals on mine and the instructions actually say to rotate it. If you do have to move the sleeve to get it properly secured you can always take it in and have it aligned. Mine was due for an alignment anyway at the time so I wasn't out anything. But I would try to just move the bracket and see if you push it far enough out of the way but still have it secure the sleeve from rotating.
Done. Hardest part trying to spread the clamps holding the sleeve so I don't mess up the alignment while rotating the clamps up. Just took a while to find the right spreading tool. Overall good improvement to the steering feel. Might still need to adjust the steering box to make it even better.
