Help mark, Sluggish when backing up
Old Mar 26, 2013 | 07:53 PM
Jojoca's Avatar
Jojoca
First off I have a 1999 f250 diesel with the noisy torque converter. It also has a banks trans command that I'm getting a delete plug to disconnect it because it shifts at awkward times. Lately though it has gotten to where I will start backing up and it will lose power and make what sounds like a dieseling sound like a car with to high of compression. If I give it more throttle it seems to go away. I thought mark said that that could be a sign of the transmission getting ready to fail to someone else with a similar problem but can't find the thread now. Could I be just the trans command not working right?
Old Mar 26, 2013 | 09:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be the torque converter clutch drifting on. This can be caused by a bad torque converter, worn pump, leaking seals, etc. A Trans Command will tend to make this worse.
Old Mar 26, 2013 | 09:28 PM
Jojoca's Avatar
Jojoca
So you think replacing the torque converter would be a wise investment then? How can I tell if the pump is bad while the transmission is out?
Old Mar 27, 2013 | 09:16 AM
Mark Kovalsky
Yes, I think you need a converter. You can disassemble the pump and measure the pieces a good manual will have pump clearances in it. You can get a manual from Automatic Transmission Service Group.
Old Mar 27, 2013 | 11:59 AM
Jojoca's Avatar
Jojoca
I sure appreciate the your advice.
Old Apr 3, 2013 | 07:10 PM
Jojoca's Avatar
Jojoca
Well I finally got my bypass plug from banks and it made a world of difference on the shifting. It no longer bogs down when in reverse also.
pb0000
Feb 22, 2019 01:00 AM
Jsamsonite
Jun 18, 2015 06:54 AM
MONAVIERONJON
Feb 3, 2015 11:02 AM
btorear
Jan 1, 2009 08:38 PM
2FordTrucks
May 8, 2003 12:05 AM
