New ignition switch actuator. Can't install!
Old Mar 26, 2013 | 05:15 PM
alhauger's Avatar
alhauger
Hey fellas. Got a new ignition switch actuator linkage (commonly broken pot-metal piece), but i can't get it installed. The old one came out easy since it was broken, but the new one has no way of getting around the tilt mechanism to slide into it's hole. I cant figure out how to disassemble or remove the tilt mechanism. Anybody got a tip?
https://www.ford-trucks.com/user_gal...d=208709&.jpg=
In this diagram, it's part 14 im trying to install. Part 15 is in my way.
Old Mar 26, 2013 | 05:43 PM
dort's Avatar
dort
Here is a blow up of the column you got to take the column apart starting at the wheel
Old Mar 26, 2013 | 05:55 PM
JWC 3's Avatar
JWC 3
You have to dismantle it to install the rack . Pull the tilt head , and it will go in .
Old Mar 26, 2013 | 07:03 PM
alhauger's Avatar
alhauger
I knew I had to disassemble it guys. I said that in the first post. I figured it out. Thanks anyways.
Thinlizzy13
Aug 2, 2019 08:49 PM
lauxg
Jun 21, 2019 07:32 AM
ozark1
29
Jan 26, 2018 11:35 AM
kevin206
Jan 20, 2014 08:00 PM
edf250
Sep 17, 2010 07:31 AM
