Adrenaline problem
Old Mar 25, 2013 | 07:18 PM
36couper's Avatar
36couper
Adrenaline problem
I did an intro a few weeks ago.
I recently bought a 2008 Sport Trac Adrenaline. I love the truck.....until today.
I went to start it after coming out of Costco and it started but was idling rough. I got it to eventually smooth out by increasing the RPM's.
On the way out of the parking lot it stalled. The starter turns the motor fine but it won't fire.
The first thing that came to mind was an O2 sensor. It has about 70k miles on it.
I bought the truck after my last non-Ford spun the timing chain which ended up costing me $5k to repair. I dumped it immediately after its repair. I bought the Sport Trac hoping for miles and miles of trouble free driving.
Any other ideas on what the problem could be?
Old Mar 25, 2013 | 07:46 PM
oneowner83's Avatar
oneowner83
Could be lots of things (of course) but I would clean the throttle body valve with carb cleaner, both sides of it. Pull off the air tube to the TB and there it is!
Then clean it twice a year...keeps you outta trouble
Old Mar 25, 2013 | 08:42 PM
Ford_Six's Avatar
Ford_Six
Check the basics- Does it have spark and fuel?
An O2s won't make it shut down completely, it'll just turn on the check engine light.
Old Mar 25, 2013 | 09:16 PM
spoonchucker's Avatar
spoonchucker
Unplug and re plug in the fuel cut off switch, it has fixed 50% of the issues in my 94. Also check out the fuel pump relay under the hood (assuming it is the same as an explorer).
Old Mar 25, 2013 | 09:55 PM
36couper's Avatar
36couper
Thanks for the suggestions. I had it towed to a local mechanic who is very trustworthy. Will let you know tomorrow what the outcome is.
Old Mar 26, 2013 | 03:17 PM
36couper's Avatar
36couper
Update; So far my mechanic thinks it could be the fuel pump driver module. At least that is what the codes are showing up for him. He has one on the way from the dealer now. I wonder what they will nick me for that part??
Old Mar 26, 2013 | 03:29 PM
spoonchucker
before you let that mechanic touch it, unplug and replug the fuel shut off. My uncle had a fuel pump replaced when the shut off had simply come unplugged. Wasted $500 because he trusted a mechanic.
Old Mar 27, 2013 | 04:11 PM
36couper's Avatar
36couper
It turned out to be the fuel pump driver module. The part was $200 from the dealer plus another $200 for diagnosis and installation.
He showed me the module. the salt had eaten a hole right through it. That's the cost of living in a climate where they salt the roads in the winter!
73 fourxfour
Jun 15, 2019 10:43 PM
Harvezter
Apr 20, 2015 09:05 PM
rcb1031
19
Mar 19, 2015 03:56 PM
scotter
1997 - 2003 F150
Jan 10, 2015 11:43 AM
Smokdivr28
1997 - 2003 F150
Apr 2, 2011 09:26 PM
