Any pics?
Old Mar 25, 2013 | 06:28 PM
Labhound's Avatar
Labhound
Any pics?
Does anyone have a pic of the AOD tv cable connection at the carb on a Carter 1 barrel?
I have the cable connected at the trans but there isn't anything to hook it to on the carb?, maybe there is but, I have nothing. I even looked on the other three carbs I have but nothing there either.
Pics would really help.
Old Mar 26, 2013 | 08:24 AM
Labhound's Avatar
Labhound
From what I can tell from looking at it, the tv cable has to move with the accel cable but in the opposite direction, but, like I said, there's nothing to hook it to...?
Old Apr 2, 2013 | 05:27 PM
Labhound's Avatar
Labhound
Anyone here have a 1 br with the AOD?....
Old Apr 6, 2013 | 04:25 PM
wannavan's Avatar
wannavan
Do you have a small plastic clip on the end of your cable that looks like it will clip into a small ball metal connector ?
My throttle and tv cable [if thats what it is] are connected to the same L shaped linkage on carb. Via plastic clips that slide onto round metal linkage on carb. Throttle on top metal ball linkage..tv cable on bottom.
Perhaps you are missing the plastic clip ?
Dont know if this make sence ..if you havent solved it yet let me know and will post pictures..let me know.
1986 E-150 van. 300i6 . feedback carter 1 barrel. AOD
Old Apr 7, 2013 | 09:16 AM
Labhound's Avatar
Labhound
The only piece on the carb is where the accel cable hooks up, somewhere along the time line the carb was swapped out for a new one without the tv hook up on it.
I did make a bracket, the fourth one, test drove it and now it does shift in all gears but, I'm taking it to a trans shop for them to try and get it right.
Just to be sure, a pic of yours would really help. Thanks!
Old Apr 7, 2013 | 10:43 AM
wannavan's Avatar
wannavan
Newphotos001_zpsa2d125c7.jpg Photo by wannavan | Photobucket
Plastic tv connector in my fingers
Plastic tv connector attached to linkage
Throttle cable and tv cable attach to same linkage on carb [backwards L shape linkage]
Throttle on top of linkage ..tv on bottom .. for that push me pull you effect
Hope this makes sence ? If you need more photos let me know.
NCook
Mar 6, 2017 03:55 PM
Mutilator712
Oct 12, 2016 06:08 PM
351Cleveland C4
Feb 25, 2014 12:31 PM
BIGskinny
Aug 21, 2013 07:57 AM
LARIAT 85
Sep 24, 2007 08:35 PM
