400 351m swap
Old Jun 3, 2003 | 06:57 PM
greg2560's Avatar
greg2560
Question 400 351m swap
I have a 400 with a automatic behind it. And a 351m with a standard on it. What will I have to swap the to put one motor in the other. I know the flywheel and harmonic balancer. Will those parts swap with no problem? Or will it mess up the balancing of the motor.
Old Jun 3, 2003 | 07:54 PM
ecarter50's Avatar
ecarter50
400 351m swap
You don't need to change the harmonic balancer. Yes the flywheel/flexplate will interchange with no problems.
Old Jun 5, 2003 | 11:49 PM
greg2560's Avatar
greg2560
400 351m swap
I will have to put up the bs flag on that reply. I think you got to swap the harmonic balancer.
Old Jun 6, 2003 | 12:24 AM
bubbaf250's Avatar
bubbaf250
400 351m swap
Harmonic balancers are specific to the engine, but both 351M and 400 engines have the same crankshaft imbalance (28 oz-in), and both engines use the same flywheel and flexplate parts, with the same external balance.
Harmonic balancers can be interchanged, usually without any problem, but for absolute safety, you should use the harmonic balancer specific to the engine.
So, not only do you not need to change the harmonic balancer, but you shouldn't change the harmonic balancer (if it's the correct part in the first place).
Old Jun 6, 2003 | 06:04 AM
ecarter50's Avatar
ecarter50
400 351m swap
Why did you ask if you already knew the answer?
Old Jun 6, 2003 | 09:01 PM
Ecuri's Avatar
Ecuri
400 351m swap
A side note on harmonic balancers: There is an elastic (rubber?) ring that deforms to allow the balancer to do its job. This material degrades over time. I noticed a much happier smoother engine when I threw out my old original one and plunked down about a $100.00 for a new one.
SWDinehart
Nov 24, 2014 07:58 PM
1960fordf350
Sep 21, 2014 01:02 PM
droppedf100
Dec 19, 2013 01:48 PM
4wheeling79
Apr 1, 2007 10:28 PM
butchf250
Feb 13, 2003 09:37 PM
