Ill tune in for this one. I heard that you pull the leather off by pulling the aft part inward and then slipping the leather forward. Then there is a bolt or something if you want to take the frame off. Not sure if thats 100%. Hopefully someone will chime in. Or is willing to try this way.
Peel the armrest cover to access the bolt and remove the bolt. ---(You'll need an allen wrench).
Remove the armrest. To install, reverse the removal procedure.
If the top is worn where your elbow sits, you can simply pull the outer covers off both the driver and passenger ones off and swap them. Puts the worn part on the bottom of the passenger one. took me 20 mins to change them and looks great.
Thats a great idea, I need to do this in my truck. My drivers side arm rest is trashed after 150k
