Alternator
Old Mar 24, 2013 | 05:03 PM
F10076's Avatar
F10076
Alternator
I need a new alternator for my 76 F100 with a 360. I've found lots of different ones online, but I'm not sure which one to get. I need to be sure my replacement is a direct fit. Any help?
Thanks
Old Mar 24, 2013 | 05:07 PM
redroad's Avatar
redroad
If you have to replace alternator consider 3g alternator conversion .. See here under 3G 130-amp Alternator Retrofit https://www.ford-trucks.com/forums/1...l#post12243490
Not sure if you mean output or mechanical fit..
Old Mar 24, 2013 | 05:24 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you have factory air, it's probably a 65 amp. The other choices were 35, 40, 55 amp. They all pretty much interchange, the one big difference is whether it's a single or double groove pulley.
My truck came from the factory with a 35 amp. I replaced it with a 65 amp and it was a direct fit.
Old Mar 24, 2013 | 05:50 PM
Blue and White's Avatar
Blue and White
For factory replacement, your local autoparts store can fix you up. They should be able to get a premium reman in a couple days. Going local makes core return easier and they can take care of any warranty issues. Amp rating should be on the rating plate attached to the alternator.
Old Mar 24, 2013 | 06:05 PM
redroad's Avatar
redroad
If you are considering any upgrades like HO coil, stereo, headlight upgrades, or anything else which has a higher electrical draw puting back in a 65 amp alternator is silly .. If you want OEM case and fitment pull the one you have and have it rebuilt locally for higher output .. otherwise you can get a 3g 130 amp alternator for around $30 from the junk yard and fit it as per instructions linked to above ..
Old Mar 24, 2013 | 07:22 PM
montana_highboy's Avatar
montana_highboy
The "3G" upgrade gets bandied around this site like it's the next coming of Jesus Christ...
Yes, it's an improvement over oem but it's probably not even needed by 95% of the guys on this forum...
An oem 65 amp replacement will suffice, trust me
Old Mar 24, 2013 | 07:37 PM
redroad's Avatar
redroad
Before there even was a 3g alternator .. I had a big housing alternator built to 120 amp .. anybody that pulls a trailer and has house batteries to charge , anybody that has on board electric hydraulics, electric winch , etc. so basically anybody that uses it as a truck it's needed as well as a second battery .. 95% ? don't go getting dramatic on me Montana That's 65 amps when it has been rebuilt and has new brushes .. and $30 for 130 amps + a harness for $15 is a great deal .. Trust me !! Considering the $60 underpowered rebuild is the alternative
Old Mar 24, 2013 | 07:44 PM
montana_highboy
Sorry Redroad....80%?
Old Mar 24, 2013 | 07:50 PM
redroad's Avatar
redroad
No harm no foul
Old Mar 24, 2013 | 07:53 PM
montana_highboy
No harm no foul
Let's split the difference and call it 87.5%
Old Mar 24, 2013 | 08:40 PM
Blue and White
I've read the 3G posts and its a great swap if you need the amps and can find a good JY alternator. If you want to start with a new or premium reman alternator 3G is very pricey.
The OP didn't state electrical needs... if loads are stock or near, the 65A reman should work fine. I run around in my Dent with a 40A (!). If he's running dual batteries, winch, trailer, big stereo, snow plow ect. upgrade is in order.
Old Mar 24, 2013 | 08:41 PM
redroad's Avatar
redroad
So 87.5% not using their truck as a truck
Old Mar 24, 2013 | 08:51 PM
crazy96863's Avatar
crazy96863
90% of all statistics are made up... Just saying.
Old Mar 24, 2013 | 09:01 PM
montana_highboy
My point exactly, not saying the 3G isn't an upgrade, of course it is, my only point is it's not needed in probably 90% of cases.
The 65 amp unit will suffice, or even succeed most users demand, that's not a popular statement around here, as most are 3G fan bois, but so be it.
Old Mar 24, 2013 | 09:41 PM
460me's Avatar
460me
For me the 130 amp"upgrade" was just about the some cost as replacing the original alt.
