5.4 brutal problems
Old Mar 24, 2013 | 03:39 PM
Bulkhead's Avatar
Bulkhead
5.4 brutal problems
Well I bit the bullet and had my phasers replaced along with a seal that spit out (a common problem with the 5.4)
Now my truck has a rough idle with the needle bouncing. At 1100 rpm the truck literally shakes as if the timing was pooched. When my truck warms up to operating temperatures there is no more problems. My battery light is coming on and off which I find interesting considering it is brand new.
I also had my spark plugs changed at the time...
I'm curious to know if this is a cap on coil problem as I heard that they can throw off a radio frequency tripping sensors.
It is throwing the engine light but havent taken the truck back to the Ford dealership. After a $3800 dollar repair, I'm a little miffed that they did a poor job and I'm a little hesitant on taking it back until I can more of a scope around what could be the problem.
Any insight would greatly be appreciated!
Old Mar 24, 2013 | 03:43 PM
bigunit54's Avatar
bigunit54
I would take it back and tell them it ain't running right. They should stand behind it. Just tell them you aren't happy that you spent 4 grand and truck is not running right. Pitch a fit and they should make it right.
Old Mar 24, 2013 | 04:14 PM
Nalb1221's Avatar
Nalb1221
I would definitely bring it back to them. Have them clean the mass airflow sensor and the throttle body ( although these are really easy to do yourself ). It could be a sensor or the fuel pump driver module, it can be all kinds of stuff. They did the plugs, did they replace the cops? Maybe check The plugs make sure everything is tight. It's kind of strange that the rough idle is when the engine is cold. That replaced the phasers did that fix your ticking sound? I have a slight ticking sound not as bad as others and I'm not sure what to do about it yet, my truck is running great right now I may do a full seafoam flush. Anyway hope your problem gets fixed easily and swiftly without having to spend much more money. Good luck keep us informed.
Old Mar 24, 2013 | 07:28 PM
genmischief's Avatar
genmischief
I don't know that fit pitching is appropriate, but it is certainly a good idea to go back and let them know they might have more work to do. If they try to charge you more... then pitch a fit.
-Jim
Old Mar 29, 2013 | 01:32 PM
Bulkhead's Avatar
Bulkhead
Replacing the phasers did not fix the ticking sound. I question if it is backlash in the timing chain and its slightly nicking a valve?
rodeoboxer
Modular V8 (4.6L, 5.4L)
Oct 25, 2021 06:36 AM
Fluke01
2004 - 2008 F150
Jan 11, 2016 05:25 AM
Ford-Trucker84537
Mar 15, 2011 08:58 PM
deere55
Oct 21, 2010 11:22 PM
fitmonkey1219
1997 - 2003 F150
Jan 15, 2007 08:22 PM
