Mysterious puddle
Old Mar 23, 2013 | 01:36 AM
kegomatix's Avatar
kegomatix
Mysterious puddle
Above the water pump, below the distributor, in that pocket on the block there is always a puddle of water. I dont get it. It can be a really hot day with no rain or anything and without fail there will be water resting there. My coolant level is never low... Ever.. That's the most confusing part to me. At first I figured the water pump was letting it seep out around the gasket, but out of all this time I haven't had to top off the coolant at all (4 months). I don't understand where this water is coming from. Anybody experience this?
Old Mar 23, 2013 | 04:47 AM
Nathanl25's Avatar
Nathanl25
Yeah, when I pressure tested the system, I found that the bottom side of the thermostat housing was getting just damp enough to drip ever so often.
Also found out that my radiator cap was malfunctioning, and allowing the pressure to build up to like 20psi...
After replacing the cap, the puddle went away.
Old Mar 23, 2013 | 07:04 AM
kegomatix's Avatar
kegomatix
No kidding? Well that solution seems about as weird as the problem so I'll give that a shot lol. Thanks.
Old Mar 23, 2013 | 07:59 AM
Nathanl25's Avatar
Nathanl25
I would pressure test just to make sure. Hell most car part places lend out those testers.
steelandspeed
20
May 22, 2019 11:48 AM
LarryC
Oct 2, 2013 10:47 AM
midapo
Mar 6, 2011 10:39 PM
GIB250
Feb 19, 2011 07:50 PM
dvldog458
13
Jun 25, 2006 11:03 PM
