Voltmeter
Old Mar 22, 2013 | 10:09 PM
Boodrow379's Avatar
Boodrow379
Voltmeter
Where do you guys hook the positive wire from a voltmeter? Some people tell me the cilinoid or directly to the battery
Old Mar 23, 2013 | 05:19 PM
Boodrow379's Avatar
Boodrow379
85 veiws and nobody knows how to hook up a gauge
Old Mar 23, 2013 | 05:39 PM
60F100's Avatar
60F100
You want it from any 12 volt source that is only hot when the key is on. If you hook it to the battery it will read all the time and will put a small drain on the battery. Do not hook it to the coil as the coil should not have a full 12 volts while running.
Old Mar 23, 2013 | 08:09 PM
Ford_Six's Avatar
Ford_Six
Hook it to the accessory lead off the key switch (radio power).
Old Mar 23, 2013 | 08:17 PM
Boodrow379's Avatar
Boodrow379
ok I'll do it thank you for the replys
Old Mar 24, 2013 | 10:35 PM
08midget08's Avatar
08midget08
I hooked mine in fuse box make sure it is a fuse that is hot only when key is on
hotrodjohn71
Jan 18, 2018 05:37 AM
v650
Aug 4, 2013 03:27 PM
87 f250
May 12, 2013 07:57 AM
Unimog005
Electrical Systems/Wiring
Apr 26, 2012 12:17 PM
busted knuckle
Dec 19, 2005 06:42 AM
