disc brake upgrade help
Old Mar 24, 2013 | 02:45 PM
jawilliams00721's Avatar
jawilliams00721
ok I finally just finished my disc brake upgrade on my 72 but i took it to a alignment shop and they couldn't get the alignment done. They were saying the outer tie rod needs to be a little shorter because they ran out of room when using the adjustment sleeve. the disc set up i have is off a 74 and the tie rods i purchased new were for a 74. does anyone have any ideas on this? please help i want to drive my truck but with the alignment off I can't yet. does anyone know of a different outer tie rod end that might be shorter and still fit our trucks?
Old Mar 24, 2013 | 05:03 PM
jowilker's Avatar
jowilker
Did you install the complete I-beam set of was it piecemeal?
John
Old Mar 24, 2013 | 08:13 PM
jawilliams00721
piece meal
I also lowered the truck using the djm setup on front and rear
Old Mar 24, 2013 | 10:25 PM
toddspeed's Avatar
toddspeed
ahhhh you didn't mention that on the other forum
Did you get the tie rod extenders? That may be exactly your problem.
Old Mar 25, 2013 | 12:53 AM
jawilliams00721
yes i got the extenders also
Old Mar 25, 2013 | 05:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jawilliams00721
OK, I finally just finished my disc brake upgrade on my 1972 F100 but I took it to a alignment shop and they couldn't get the alignment done.
The disc setup Ihave is off a 1974 and the tie rods I purchased new were for a 1974.
I also lowered the truck using the DJM setup on front and rear.
D2TZ-3A130-B .. Tie Rod End ~ SAME: 1972/79 F100 2WD / 1975/79 F150 2WD.
D3TZ-3A131-A .. Left Outer Tie Rod ~ SAME: 1973/79 F100 2WD / 1975/79 F150 2WD.
D2TZ-3281-A .. Adjusting Sleeve ~ SAME: 1972/79 F100 2WD / 1975/79 F150 2WD.
D3TZ-3304-B .. Draglink-40 3/8" long ~ SAME: 1973/79 F100 2WD / 1975/79 F150 2WD.
Outer tie rod connects to left spindle, tie rod end connects to draglink that connects to right spindle. Adjusting sleeve between outer tie rod and tie rod end.
The problem is, you lowered the truck. Another thing to consider...did you buy the correct parts?
KsHighboy
19
Sep 25, 2016 07:55 AM
blueoval66
May 30, 2005 07:53 PM
giblot
Nov 1, 2002 02:43 PM
jowilker
Feb 23, 2000 09:04 AM
