Looks like a different winter and summer weight will be in order.
Yep especially where you live .. Those villages that are running remote generators and equipment up there where you live probably have a good idea what oil weight to run in Winter and Summer also ..
Where I live, it is more temperate that the blistering cold that hits the interior or the northern part. I could possibly get away with running 10w30 or 5w40 all year long. Our summers don't get quite as hot as you all's.
Plus, with my work schedule (I work at a remote site), the truck will not see a huge number of miles per year.
I see so you only do one oil change a year anyway?
Being in Alaska you also have the new Rotella T6 0W40 you could use, that is if you plan on starting your truck at -30 with no block heater.
We won't get 0W40 in Colorado until next year.
Otherwise for year round use with little to no towing I would use Rotella 10W30. Or dump it in Spring for 15W40 for the warmer months with towing and then switch back.
