just bought a 94 explorer
Old Mar 22, 2013 | 04:47 AM
LittleRedRanger4.0's Avatar
LittleRedRanger4.0
im proud to say i own an explorer. my new 1994 explorer 4dr 4wd auto. its white with red interior 98,000 miles. the a/c needs recharging and the autolock hubs dont work so any info on those would be wonderful. i used to own a 1987 F-250 6.9 idi. this vehicle is wonderful. i have axle code D4 what does tha mean?
Old May 28, 2013 | 10:24 PM
redhawkssh44's Avatar
redhawkssh44
D4 axle code refers to a gear ratio of 3.73 with a limited slip differential.
Old May 29, 2013 | 06:47 AM
shorod's Avatar
shorod
Can you tell if the A/C was ever converter over to R-134a or if it still has the R-12 (Freon) fittings? If it hasn't been converted yet, you'll want to at least plan for that expense. Well, even if it has been converted, it may not have been done correctly. Unless you know the history of the system, you may want to budget for a complete conversion anyway.
I seem to recall some discussion awhile back regarding common issues with the early auto-locking hubs in the Explorer. You might try searching the forum for details on that system and issues. I think there is a pretty common conversion to converter to manual locking hubs if you're interested in that.
-Rod
Blade79
Apr 3, 2014 11:53 AM
samo1056
Nov 16, 2003 11:15 AM
CdnSoldier
Jun 3, 2002 09:51 PM
venumb
Bronco II
Dec 27, 2000 10:06 PM
